05stroker
Never enough power guy!
Okay so while I learn how to drive my car again this year I am already thinking of the next phase this winter.
I want MOAR cubic inches!
That said I am thinking either a 326 CID big bore with a 3.8 stroker crank or a 5.4 block with a stock stroke and 358 CID with 3.7 pistons. I think my current head work and setup will respond really well with more cubes and unshrouding the valves with the 3.7 bore. . I think a larger cam would be needed though. Maybe start with the Comp 127650 cams. Obviously the 5.4 will require a severe modification to my JPC intake, I'm good with that, it will have to have the tubes lengthened and recoated.
The thing is, as much as I can and have done with my current setup, that is the extent of my knowledge on the modular platform. So, I am asking for help from those that have experience with these other setups. Keep in mind I will stay with 20+ psi and high compression with E85. I would like to hear pros and cons ect.
