That Did It!!! It Is Fixed!!!!!!!!
Well I drove it. What can I say except now it acts just as if it has a throttle cable on it!!!
This is all I got to say about "Tube's" findings:
The part throttle driveability is now simply outstanding. Just the slightest touch of the gas pedal now makes the car actually GO! It is so much easier to drive now from a dead stop or slow speed.
Idle is fine (600-700 in D), and no CELs. WOT works just as it did before.
I also noticed two other things:
1. When you back off the gas it now feels as if the throttle is closing completely. I can feel that "snap" sensation in the drivetrain when I let off the throttle.
2. At about 40-45mph with OD engaged and the torque converter locked, a slight jab of the gas pedal immediately causes my torque converter to unlock and the revs jump!
That was well worth the time I spent on it this morning as it has fixed what I have been bitching about for months!!!!!!!
By the way, the mod I did technically DOES NOT require you to remove the entire gas pedal assembly! You can do it with the damn thing still attached. Although it is a major pain in the ass to crawl up in there to work, but hey, I'm 46 and my old back ain't what it used to be!
Of course I removed mine just to take a good gander at it and saw right quick that I could do a simpler mod with a piece of tape!!!
Hope this helps.
Mike
