SilentScope
Chemist by profession
Wanna use your brakes less at the track? Attach them to a shift light on the dash so u can see how much you use the brakes. Try to have that light come on as little as possible and you'll be golden.
I'm not too concerned about dust. I plan on keeping my original set of pads and rotors for the street and dedicating a different set for the track.Carbotecs make A LOT of brake dust
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
I hate to go against the flow, but your rotors look ok to me. Most street pads will overheat and start to shudder when they get used at the track. It's caused by pad material melting onto the face of the rotor. As they cool down, the melted material gets scrubbed off and the shuddering stops.
If the brakes are fine on the street, then just get some proper track pads for the track and the problem will either be reduced or gone altogether.
i think most people refer to the uneven deposits as "rotor warp" these days. yes you are correct as they are not actually warped but have an uneven layer of pad friction deposit.
in the end, i even still call them warped rotors.
I gave up. Way too much misinformation floating around.
To the OP, do a little search on the topic by people like SoundGuyDave. Plenty of good info available.
