Need some quick help
RedfireGT
red hook, new york
ok. Need some help here.
I put the fr500s on the gt500 and ever since i put them on, i feel the steering wheel shake back and forth quickly for a while and then is normal for a bit, then does it again. I had the wheels re-balanced and added necessary weight to make sure that it was perfectly balanced. And it felt fine for like 5 minutes, then it started the shaking again. It did not do it with the other wheels that came with the car. Not sure what it is.
any help?
note: It did this before i lowered the car as well.
AlloyGT
Lurker
Highlands Ranch
Did you remove the washers that go over the studs, to retain the rotors? I remember reading that these are a problem with some rims. They keep the rim from mounting flush against the hub.
RedfireGT
red hook, new york
Did you remove the washers that go over the studs, to retain the rotors? I remember reading that these are a problem with some rims. They keep the rim from mounting flush against the rotor.
I did not see any washers. But i shall check.
AlloyGT
Lurker
Highlands Ranch
I think the stock rims have like indentations on the back where they meet the hub, and this allows them to clear the washers. There's only one or two washers per hub. So when you put a rim on without the indentations, the rim isn't "square" to the hub, if that makes sense.
calispecial08
I've seen the same thing, it can cause shaking, they are only on there to hold the rotors on when the car is on the assembly line. If they are on there take them off and see if it helps.
JeremyH
3V Fuel Guru
Virginia Beach
Good advice.
A tire could be out of round as well. It will still balance on the machine but will causing vibs/issues while rolling.
RedfireGT
red hook, new york
The car did not come with stock wheels when i bought it. But i will check this out.
nv4gt ws
RedShift
va beach
prob need to be rebalanced or correct lug nuts. am sent me the wrong lug nuts when i pur my wheels and tires. but balance problems are common with online tire and wheel pur.
retfr8flyr
The Old One
Providence Forge, VA
You need to find a tire place that has a Road Force balance machine. Some times a wheel will balance fine on the machine but will still cause problems when mounted on the car. It has to be a problem with the new wheels and tires since it was fine before the install.
Earl
RedfireGT
red hook, new york
You need to find a tire place that does a road force balance. Some times a wheel will balance fine on the machine but will still cause problems when mounted on the car. It had to be a problem with the new wheels and tires since it was fine before the install.
Earl
My friend works at toyota and they do road force.
i changed the lug nuts when i put the new wheels on. im gna go back to the old ones and see if that fixes it
RedfireGT
red hook, new york
Okay, i put the old lug nuts back on and checked for the washers there. So now im stumped. Not sure what to do. call American Muscle?
whoapony
Clarksville, TN
If you have the same size tires on all four corners, try putting the fronts on the back and the back on the front and see if the shaking stops. If it does then it could be an out of balanced tire, if not then it more than likely is the rotors.
Also, are your wheels center balanced, inner or inner/outer. If its just center only thats pretty tough to balance.
dans08gt
the white ghost
i bought a set of tires from cruizin concepts and had the same problem. had to re-balance both front tires but one of the tires had to be broken from the bead and rotated 180 deg.
nv4gt ws
RedShift
va beach
Why are those wrong? What's wrong with those?
they dont have a bulge end and will dig into the wheel. i went round and round with am about this. finally talked to the right guy and he was gonna correct the problem. dont know if they are sending out correct ones now, but they gave me a credit.
RedfireGT
red hook, new york
the rear are bigger then the fronts so i cant rotate. And the are inner/outer balanced.
i had those and put them on, i changed back to the old ones and they still did it. I ordered the ones u just gave a link to and ill see if they do it.
