TSB Lists for 05-07 Mustang GT 4.6L.
DynoJoe
cleaning out your closet
Houston, Texas
Technical Service Bulletins
2005 MUSTANG - US (English)
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-15
MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-9-14
CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-8
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005
05-8-6
EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-4-8
FUEL FILL SLOW, OR DIFFICULT TO FILL
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-14-7
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
I will update this more this afternoon.
C
Casper98gt
Guest
2005 Mustang TSB's
2005 MUSTANG - US (English) UPDATED: 6-15-06
06-14-3
AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH
06-12-11
LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
06-10-13
MIL P0463 OR ERRATIC FUEL GAUGE
06-10-10
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-10-1
06-9-9
HESITATION ON ACCELERATION AFTER LONG CRUISE
06-7-10
MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
06-5-4
PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING
06-4-9
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
06-4-7
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
06-4-2
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
06-4-1
RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-3-13
06-2-9
DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
05-24-6
CONVERTIBLE SYSTEM CONCERNS
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-2
05-20-2
REAR AXLE NOISE
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-16-12
05-15-13
FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE
4/26/2005
05-15-8
05-15-2
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
05-9-18
05-9-14
05-9-11
05-9-3
05-8-6
05-7-3
05-6-15
05-3-1
04-26-22
04-26-16
04-24-20
04-24-14
04-24-5
04-16-1
04-9-6
C
Casper98gt
Guest
2006 Mustang TSB's
2006 MUSTANG
UPDATED: 3-17-07
07-5-13
DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE
07-5-8
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-3-9
MIL ON - DTC P0456
07-1-7
MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-2
CARPET REMOVE AND REPLACE
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-22-18
POWER WINDOW DIAGNOSIS
06-22-16
CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7
06-19-12
06-19-2
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
06-18-16
IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP
06-17-8
06-15-8
KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY
06-14-3
06-12-11
06-10-13
06-10-10
06-10-5
5R55S - TRANSMISSION FLUID LEAK
06-10-1
06-9-11
LOUD TICKING NOISE - 3-VALVE ENGINES - STUCK LASH ADJUSTER
06-9-9
06-7-10
06-5-4
06-4-2
06-4-1
06-3-13
06-2-9
06-1-5
DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS
05-24-6
05-22-8
05-20-2
REAR AXLE NOISE
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
05-9-18
05-9-3
C
Casper98gt
Guest
2007 Mustang TSB's
2007 MUSTANG
UPDATED: 3-17-07
07-6-7
SPOILER/DECK LID CONTACT
07-5-13
07-5-8
07-4-3
07-1-7
06-26-2
06-26-1
06-25-15
06-25-3
PIONEER NAVIGATION RADIO - SEEK FUNCTION INOPERATIVE - SERVICE TIP
06-22-18
06-22-16
06-21-19
06-21-7
06-19-2
06-17-8
Hawgman
THE fucking bad guy
04-9-6
Body - Paint - Iron Particle Removal - Industrial Fallout - Acid Rain Neutralization
  • tsb04_09_06.pdf
Hawgman
THE fucking bad guy
04-14-7
Service Wiring Harness Replacement Guidelines - Service Tips
  • tsb04_14_07.pdf
Hawgman
THE fucking bad guy
04-16-1
Engine Misfire Or Rough Running - Coil On Plug (cop) Ignition Systems - Wds Cop Kit Diagnostic Tips
  • tsb04_16_01.pdf
Hawgman
THE fucking bad guy
04-24-5
Rear Window Defroster Grid/integral Antenna Diagnosis And Repair - Terminal Tab Repair
  • tsb04_24_05.pdf
Hawgman
THE fucking bad guy
04-24-14
General Pcm Programming Procedures
  • tsb04_24_14.pdf
Hawgman
THE fucking bad guy
04-24-20
Limited Slip Axle Chatter, Shudder, Binding Sensation, Or Vibration During Low Speed Turning Maneuvers
  • tsb04_24_20.pdf
Hawgman
THE fucking bad guy
04-26-16
Weld Bonding Procedure
  • tsb04_26_16.pdf
Hawgman
THE fucking bad guy
05-3-1
Maf Diagnostic Service Tip - Vehicles Equipped With Egr System Module (esm)
  • tsb05_03_01.pdf
Hawgman
THE fucking bad guy
05-4-8
Fuel Fill Slow, Or Difficult To Fill
  • tsb05_04_08.pdf
Hawgman
THE fucking bad guy
05-06-09
Intermittend CD Player Concerns
  • tsb05_06_09.pdf
Hawgman
THE fucking bad guy
05-6-15
Air Bag Warning Lamp On - Dtc B1891 In Restraints Control Module Or Lamp Flashes Code 53 - Vehicles Built Before 10/02/2004
  • tsb05_06_15.pdf
Hawgman
THE fucking bad guy
05-14-04
Wrench Light On With Both DTC P2106 And P2135 - Vehicles Built 11/29/2004 And Prior
  • tsb05-14-04.pdf
Hawgman
THE fucking bad guy
05-7-3
Axle Whine - Vehicles Built Through 11/15/2004
  • tsb05_7_3.pdf
Hawgman
THE fucking bad guy
05-8-6
Exhaust Vibration At 850 Rpm - 4.0l Engine And Automatic Transmission
  • tsb05_08_06.pdf
Hawgman
THE fucking bad guy
05-8-8
Growl/grinding Noise In 2nd Or 3rd Gear During Deceleration - Tr3650 Manual Transmission - Vehicles Built Before 1/15/2005
  • tsb05_08_08.pdf
