mot250
- Joined
- Oct 6, 2010
- Posts
- 137
- Reaction score
- 0
A Royal Purple rep told me to use their Syncromax for the 2005 and up manual 5 Spd.
Proab will change mine every other oil change on the FR and once a year on the street 05.
I'm going to change mine more as an upgrade rather than a maintenance thing. I'll worry about it again if and when the transmission ever needs to come out of the car.
About how many miles would that be between changes?
Regardless, that sounds a bit excessive. If you are going to do it that often, I'd suggest you get the first few fluid drainings analyzed for the amount of wear particals then adjust the drain interval based on those findings.
My ford dealers said the mercon V never needs to be replaced. hmm.
I use Royal Purple.
