FalconGTHO
The Reporter
too small of or not enough blow off valve size? Applies to a D1sc application.
I've been fighting a balance of noise and pressure relief with my F1C/setup. That big blower moves a ton of air, so I've got a couple valves on it to help relieve it when off the throttle. One of them is the standard stage II Procharger valve with the little filter and it's not big enough to handle it by itself. So I also have a 50mm BOV on it that's adjustable. With the 50mm loosened up so it opens all the way when I let off the car sounds like a damn street sweeper (likely louder than a street sweeper). I hate it. It works the best, but I hate it. If I tighten up the valve so it only opens partially under higher boost, I get hanging idle and slight compressor surge in certain situations. But the car is reasonably quiet at part throttle that way, and is more pleasant to drive (it's a street car after all, not a race car).
Thats what mine "used" to sound like when I had the P1 and the mondo bypass. Upgraded to a D1 and the bypass would make a fluttering sound. This would happen even if I wasn't in full boost. (My car wasn't tuned)
Now that it is getting tuned the inlet pipe keeps getting blown off the TB, and this is with the T-Bolt clamps on it.
The thinking is that the bypass isn't big enough. For reference its a D1SC with a 3.4 pulley and custom 3" piping throughout.
You're moving a lot of air with a D1 and 3.4" pulley. Fluttering is definitely a lack of flow through the valve. I would think the Mondo would keep up though. Make sure it's opening all the way, make sure it's got a good strong vacuum source, and make sure there are no flow restrictions at the valve mounting point, or valve exit point (dump to atmosphere or no?)
It usually takes more than 12psi to blow piping off![]()
Vacuum blows piping off. Granted since I have FRPP cams I do have a little less vacuum, but not by much. I'll still pull -20 or so on the gauge.
Eh? Unless you're saying that not enough vacuum can cause the valve to not open all the way... Either way, vacuum doesn't blow piping off.
Why do they always come off on decel then ? There's no boost going on then. I think the TB slamming shut and the engine pulling alot of vacuum during that process is what causes the pipes to pop off. Please correct me with facts if that is wrong.
