Thinking about going all the way now.
Marc s
NASA AIX
Auburn, WA
Cut the Prochamber out and installed a 3 chamber flowmaster in it's place. The pipe spacing for the Prochamber and Flowmaster where the same. Next, the fuel tank needs to come out so I can run the exhaust out the side of the body.
Surprising how good the flowmaster sounds. It's still damn loud though. I can't wait to hear the 3" through body exhaust.
Marc s
NASA AIX
Auburn, WA
Making more progress. I decided to use a quick fill system like on the FR500C. However, I didn't want to have to raise the trunk lid to fill it. I bought a 71 Mach1 fuel fill cap and cut the center out of it so it will be functional.
Dare to be different right.
I will only use one though.
I also made some progress on the through body exhaust. I have one side almost done. I used a 4" hole saw to cut through the body and a plasma cutter to cut through the subframe. I then took 1/4" wall pipe and slide it into the subframe and welded it on both sides. After that, I will fish plate the inside and tie a cage support into it. To finish it off, I have 20ga stainless steel that I will use to cover the lower quarter panel and a stainless 3 1/4" tip will exit through it.
Marc s
NASA AIX
Auburn, WA
Now that is sick Marc!!! Good work!!
Why did you end up going with the Flowmaster?
I wanted something as quiet as possible and I thought a twin inlet/outlet Magnaflow would burn out after extended time on the road course. As it turns out, even the 3 chamber is pretty loud. We all know the Flowmaster axle backs don't sound that good on the 3V's. However, with it mid mounted, it sounds just like an older 5.0.
striker 5
$$$$$$$$$$$$$$$$$$$$$ spend it you'll make more or pimp your mom oh I'am bad lol
