Spring Rates?
trakhoar
Can you post the spring rates of all your springs for the 11-12 Mustang GT, and if you have the stock rates for reference
Thanks. Im on the fence between the sport and ultra-light springs, they seem to have a similar drop rate so curious as to what the spring rate difference is
S
Steedagus
Guest
555-8206 Steeda Ultra Lites - 195lb front, 175lb rear
555-8215 Steeda Sport Springs 200lb front, 175lb rear
555-8220 New Steeda 05-12 GT Convertible sport springs 200lb front, 190lb rear
555-8245 - New Steeda Comp Springs Boss 302 and GT 225lb front, 195lb rear.
I have some stock hardtop spring rates
05-09 GT 134lb front, 120lb rear
2012 Boss 302 134lb front, 181lb rear.
way2qk4u2c
Austin Tx
What is the advantage of having stronger spring rates? how is the competition springs better than the sport springs?
S
Steedagus
Guest
Handling is the advantage. The disadvantage is once you go high enough in spring rate you need better shocks and struts to achieve proper wheel control and maintain ride quality, however many people plan on upgrading their shocks and struts anyway so to some its not a disadvantage at all.
Ivan 5.0
Still learning...
NoVA
Then is it safe to say that Steeda Competition springs will provide the best handling when used with upgraded shocks/struts?
What are the factory springs rates on the 2011 GT?
Mike K
WANNA BE FAST
Richfield, MN
I'm also looking for some upgraded springs. Would my stock saleen struts/shocks be ok for some comp spring?
S
Steedagus
Guest
Hard to judge that this way, how long have then been on the car? Who made those back then for Saleen? They may be compatible but I would need to know a little more about them to answer this question accurately.
S
Steedagus
Guest
I searched and I do not have exact 2011 GT spring rates handy before posting this. I believe the front spring rate is still around 134lb in the front, I dont have the rear spring rate handy though.
Mike K
WANNA BE FAST
Richfield, MN
I have 36k on the car and I'm not sure who made them saleen. Maybe koni...
BMR Tech
Traction Vendor
Tampa, FL
I don't mean to hi-jack, but during our lowering spring redesign we found that the new 2011 Mustang GT rear spring is a 154lb/in. (This is why we redesigned our springs)
We also found that the front spring was slightly softer than the previous 05-10 GT.
Hope that helps.
jsimmonstx
Comal County, TX
First, I recognize that this is an ancient thread, but...
I currently have dub springs (Eibach pro kit?) on my car. They were fine when the car was a V6, and even after swapping in a 351 Windsor (thanks to BMR for the k-member!), however, I recently added a 671 blower to the car, and now the springs aren't strong enough to keep the car from bottoming out.
I read somewhere that the eibach pro-kit front springs are 460-570lbs, but I don't see how that can possibly be the case if the BMR springs are only 225 at their stiffest.
What's the real story here in terms of spring rates?
