On3 turbo build
JoshK
Modder AKA Fuel
Nebraska
You had spark blowout at those levels? I wouldn't think to see spark blowout at 9.5lbs of boost. Was this on E85?
I know I will have to change out the pumps to push it.
Limetime
yes on e85. I talked to turbopete he said more timing and 9psi should also help.
he stated E85 loves timing, tomorrow i'm going to throw on a BAS and jump back on the dyno
I got the tranny out!! what a pain the plate in between the tranny and block was stuck on both sides keeping them together. I just pried the shit out of it and it budged. Unfortunately no time to get flywheel resurfaced and idk if the shop will be open tomorrow :(
Tranny is in and new clutch installed. Shaved off those stupid brackets or whatever you call them off tranny. It made putting it back in so much easier. Starting on the kit when I get home today.
From what if seen ppl have mixed opinions. My friend has the same clutch in his termi and doesn't seem bad. I heard its near stock
Drivability.
Idk if I don't like it I'll just tough it out until I can afford a mcloid or however u spell it
JeremyH
3V Fuel Guru
Virginia Beach
Spec stage 2 doesnt do well in our cars with the hydraulic slave, Just giving you a heads up.
crmpman2
crmpman2
suffolk, Va
What kind of problems have you seen or heard of? Just asking because zexy has a spec stage 3+ and was wondering what might be happing down the road.
JeremyH
3V Fuel Guru
Virginia Beach
Its specificly the stage 2, the 3 seems to work great. Just search clutch failures or spec stage 2 issues etc.
Fml... If all goes bad at least I shaved those damn ears off. Not so bad without those.
Got a little progress today. Waiting for my coolant hoses to come. Will I be able to install cold side without those coolant hoses yet?
JoshK
Modder AKA Fuel
Nebraska
DO you have your maf flange welded onto the pipe yet? You are going to have to extend those maf wires yet.
