5.0 Twinscrew Installers - Grinding Front Cover
Wnt2gofst
Banned
Columbus GA
Not true
I have a magnuson on my 2011 automatic. The magnuson is a 2.3L TVS same as the roush - rotors and bearing plate(the silver plate on both) are bought from eaton and are the same. Housing and inlet are made in house at both magnuson and roush. my automatic car with stock airbox(drop in K&N flat panel) and stock exhaust (cats and all-minus mufflers(I run muffler delete pipes) running a 3.9 inch/99mm pulley made 6 pounds of boost and 531 rwhp. Same shop, same dyno a 2011 stick car with a roush 2.3L TVS kit with all stock exhaust and open element air filter running a 3.55 / 90mm pulley (smaller then magnuson - more boost) made 8 pounds of boost (2 psi more than mine) and the car made 518rwhp.
yes they are ugly (different) but they work! look at the E-force and Techo has front inlet and now whipple is making some front inlet designs.
And this if I got was from the designer of the Maggie. I will check see if i still have email from them. They both are tvs blowers but are different. The Maggie has a front inlet and roush has rear. There is some also other difference as well. On their Facebook as well they have a grabber blue one with full exhaust 10lbs only made 540whp.
Samsung Galaxy 2-better then your iPhone..
kdanner
Austin
Who the hell cares about a dyno number, what do they run at the track? I run 10.90s with 410rwhp.
slvr08gt
Vilseck, Germany (Rose Barracks)
Im sure you have quite a bit of suspension to run those numbers with just over 400whp.
Also there is a HUGE difference between 10.90's and 9.90's that ALOT of 5.0's are capable of with different types of FI. I just dont see a maggie 5.0 dipping in to the 9's any time soon.
-Nick
blackgt87
Can anybody with a stick shift FI 5.0 tell me their trap speed? Almost all the numbers I see are from auto cars, and those are few and far between. I am hoping to go Kenne Bell 2.8LC real soon here and would like to trap 130+ on 93 octane. Just curiuos as to how some of you guys are running.
Dyno numbers mean much less than mph to me.
kdanner
Austin
-Nick
Yeah I have aftermarket control arms on the rear. Is that "quite a bit"?
Sure there's a big difference between 10.90 and 9.90. The point was dyno numbers don't have jack to do with it.
I'd be interested to hear whatever else the faux cobra jet above has in addition to the blower. 10.63 tells me they aren't junk.
2005mach1
michigan
10.63 @ 130 is with long tubes, off road H and muffler deletes. stock air box with k & N flat panel. 3.9 inch pulley makes 6psi. automatic with circle D 3000 stall and 3.73 gear. d spec and cobra jet springs, upper control and mount and lower control arms
RI_2011_GT
Rhode Island
Do you provide directions for installation of the front cover when it is purchased? Is this what you do when you install a kit for $720?
lostsoul
2014 vett or 2015 stang..
Gay Area
thats fine for the track but 95% also use it mainly on the streets where there are no slicks, prepped roads, tire warm ups and sometimes you need the power when rolling..
Your car is not stock HP so it must have been important to you just like millions of others.. I always laugh at people that say things like that.
Good ol' Don_W used to say that... why did he leave us
S197 GT
PINK Casting Director
Nor Cal
Boy this thread has really gone off topic.
Sure has.
Please leave the tech thread as a tech thread.
ET's don't really have anything to do with the grinding of the timing cover. Let's keep it to the topic and the off topic chatter to a minimum.
Scuba-Matt
Boost freak
SE Florida
Anyone have a pic of the new cover that has been ground? Or the Roush updated pic from their new directions?
2c5s
S. Ca
I trapped 130mph with almost 50 less wheel than I'm at today. Stock suspension, 1.8 60ft. Decent west coast air, 91 octance with Torco.
Bud
Northern Colorado
I havent seen one of the new covers up close and personal, but I would almost think that you could use the new tensioner and idler pulley instead of the massive and pain in the butt FEAD bracket.
Will be curious if this ends up being usable in the future. Would make belt swaps a little easier.
