Coyote POWA
KenB
Thanks everyone. LOTS going on and I will try and post some pics soon. Engine got here Monday, its all dressed and ready to go in. Jake is working on the fuel system also. Hopefully I'll have some pics up later today or tomorrow.
Mystickeith50
South Jersey
What's taking so long?........jk. I have been waiting to see more pics of this build. It's been such an entreating thread for me at least. I kinda wish mike would have messed up on the shipping label for that motor and it could have ended up at my house. Lol.
KenB
Thanks!
Im running a bit behind at updates because so much is happening. I'm sure you guys want to know what's going on with the car, I'll try and do some picture updates soon on that. But we are on target for Bradenton, working on the fuel system.
But I'm going to switch gears for the moment because I wanted to show you some very cool stuff related to the production system. We really want to do this right but at the same time, that doesn't mean the kit has to be super expensive. The y pipe that connects the two turbos and also has the BOV mounted to it works flawlessly. But as you can see in the picture, there is a lot of welding involved. This is the prototype, it probably could be simplified to be a little easier to fabricate, but it will still be a time consuming piece to make. Plus, the more welding there is, the bigger chance you have for mistakes, cracks, or pipes that don't all come out the same. So we decided to take a different route and get this piece cast. It is a sizable investment up front, but it will keep the cost of the kit down and every pipe will be exactly the same.
I was lucky enough to find a guy to work with on this on another forum and it has been a great experience. His name is Garen Phillips and he works for DiamondP. I PM'd him and was super helpful from the get go on how it's all done. I talked to him about getting it cast through them and he said he could also take our design and redo it in Solidworks. I just sent him a picture with the measurements drawn on it because we only had one pipe and it was on the car.
Here is the current pipe:
He got it all done in a few days and sent me the model so we could compare it.
Here are some renderings:
Then the car came apart for upgrades so we sent him the pipe so he could double check it. Next step was to print it out which he did for us as well.
The pipe arrived today. The car is still going together so we haven't test fitted it yet, but it looks perfect. The BOV fits with not issues. (forgot a pic of that).
His his service has been top notch. I would recommend working with them if you have a project like this.
Best part?
Designed and Built in the
USA!!!!!!!!!!!
KenB
ABS plastic?
Not sure what that's made of honestly. That's just to test fit it. It will be cast aluminum. It will be a higher grade alloy and heat treated. It will be overbuilt, just like the whole kit. :)
KenB
Thanks guys.
Engine is getting dropped in today. here are some teaser pics of the hotside coating and the Boss intake set up with 205 lb/hr injectors.
