"Plasti-Dip"ing wheels
chutoyy
Seattle-ish, WA
Plasti-dipped my wheels. :) If you decide to do this... make sure you spray a THICK coat on or else it'll be a PITA to peel off after a few months...
calispecial08
Has anyone done it to wheels that have bolts all the way around the wheels by the spokes? Just wondered how hard it would be to get the plastidip to cover all of those as well and how difficult it would be to peel off of them.
You can apply multiple coats. In fact, it's preferable to one extra thick coat IMO. If you have areas where it is too thin to peel it off easily then you can just add another coat and build it up a little. Then after it's dry you can peel it all off.
Agent007
Rocky Point, NC
If you guys are doing this to to rims that you use on a regular basis, I would strongly recommend rebalancing them. You will be adding several ounces of liquid weight to a wheel setup that usually only takes an ounce or so to balance. This advice comes from someone with 5 years of tire changing/balancing experience. On another note, nice job OP!
ModTechRacing
Great advice!
06ragtopgt
I'm working on a set of 2010 GT five spokes right now and had already sanded one for paint before i stumbled upon this stuff, now that wheel looks a tiny bit flatter than the others, other than that I'm very pleased with the results. Has anyone sprayed this with tires off? I'm afraid its going to rub off when i go to mount tires, but I guess I can just touch it up if necessary.
Autobot
I love this stuff. It's also okay to put on your car. I did this to test out and mockup various stripe designs.. peels right off, no problems! I also sprayed my wheels, didn't tape off the tires though. I just peeled it off afterwards.
SS KILLR
Killer of the SS
Temple Texas
Sorry to hyjack your thread, But does anyone have 18" GT stockers they plasti dipped? I'd like to see them, thanks
chutoyy
Seattle-ish, WA
The one on the right is plasti'd.
These are plastidipped and sprayed over w/ gunmetal.
Here is my entire car plasti-dipped. (well, the sides)
imsuchahotdog
Austin TX
Plasti dip everything!
I'm going to try this out i'm a couple Weeks to see how my brembo wheels look with the mods I put on it soon. This way I don't powder coat things without knowing how it will look
cwhit23
I never thought about painting a color over top of the plasti.. thats a cool idea. Hmm.. may have to get me some gunmetal now.
Mr.CuBaN
Miami, FL
i am thinking doing my whole car matte black HHHUUUMM ,,, idk lol
EDIT.. do they have matte gray??
calispecial08
From looking at Chutoyys other thread, he used the clear plastidip to make his car the matte blue color
Wicked GT
OCD with ADD...
Omaha, NE
I plasti-dipped mine and then shot a coat of Satin Black on them as that is how I was going to powder coat them. All kinds of things you can do with them.
calispecial08
Then when you peel off the plastidip the paint just comes off with the plastidip? That's awesome
sinabite
Plasti dip has become my "new primer" simply because the prep work on a piece is simply make sure it's clean.......instead of scuffing it up.
