JEWC_Motorsports
S197 Junkie
Hasn't been done yet. Gotta get 500 miles on the car and take it back.
What did the leakdown test reveal!?!?!?!?
I don't recall James saying that one was done.
I would love for a service "tech" to tell me my oil separator caused an engine failure. I would eat that reject alive.
Don't worry guys the jersey boy is more edumacated then us southerners...!
This is what I've been thinking since reading the first few pages of this thread this morning. Your oil sep is getting way too much oil in it. Hell, I run Amsoil myself and over the last 1500 miles I've not gotten a 1/4 of the oil in mine that you have in yours.
With the sputtering and all, I'm of the opinion that something int he PCV system is dumping enough oil into your intake tract to cause smoking, stuttering and backfiring issues. I've had these exact symptoms on other cars/trucks that had a PCV Valve stuck open. The higher the engine compression, the more pronounced the symptoms were.
I hope it's a quick, simple fix brother!!
If Ford made you do all that and it turns out to be just a PCV valve, well to put it nicely someone there needs to go back to tech school.
I doubt a defective PCV valve will make it burn that much oil. Maybe on a boosted application with screwed up vacuum line routing, but certainly not on a completely stock N/A motor.
If the oil is coming from the PCV valve, it's getting there via excessive blowby. The PCV valve can't pass oil into the intake tract that isn't already in the crankcase.
