Front end jack points?
94tbird
4R70W FTMFW
GIG4FUN
Rock 'n' Roll Moderator
Iowa
the V'd part threw me for a loop! holes makes more sense! THANK you for the pic! I get it now...
94tbird
4R70W FTMFW
i am gonig to cut a section out down the middle of it from end to end so the bar fits inside the wood so in a way a 'v'
ArtQ
Alpha, NJ
I have to get batteries for the camera..............But the "V" completely stabilizes it against the bar. The only difference is I only drilled enough for the bolt heads to recess leaving more meat in the wood.
94tbird
4R70W FTMFW
2" hole saw and a dril land i went to work. It worked for the moment which is what i needed. I will V it like you did as well
GI Joe
I think if you bolted a piece of flat steel to the bottom across the length it would add strength and stop that Bowing.....
cekim
Large Member
Earth
Yeah, I'd be a little paranoid of creating a "wedge" with the "V" - better to either add the strap as Joe says or, even better, that and cut a rectangular notch big enough for the width of the bar to get down in a little and rest on the bottom rather than on the sides of the "V"...
________
__|__|
Rather than:
______
__\/
What you have done there with the second one is make the tube act like a "knife", pushing the two sides of the wood down and out - rather than just compressing the wood between the bar and the jack face.
Depending on your wood, it might never split, or it might split on the first through Nth use depending on the grain... Little like using cinder blocks - they work great until that day when they disintegrate on you...
ArtQ
Alpha, NJ
The V is more like a \_/. But I agree, a |_| would be better, and 2 peices of angle iron welded together across the bottom to cradle the wood would seal the deal.
....Oh yeah, cinder blocks, man that was the approved substitute for jackstands back in the day. Wouldn't even think about it now.............
GI Joe
I remember those days too.
I just heard last week of a Master sergeant in the Air Force Working on his rear brakes on one of those little hydraulic jacks and it fell off and they found him 12 hours later.
cekim
Large Member
Earth
Ughh, that's a bad way to go...
I grew up paranoid about that having heard/seen so many horror stories about people losing all their fingers under transmissions, legs, arms and lives because of lousy jack/supports...
Heck, I even watched a kid running with a pencil put his eye out in Kindergarten - I take that "you'll poke your eye out kid" crap seriously - I've seen it done - its not good...
don_w
Dyno Numbers - Who Cares?
San Diego, CA
+1...
I currently have four heavy duty 6-ton jackstands, and as you know, the plan is to add a two post lift in the new house. Some of it has to do with safety, and some with the fact that I'm getting too old to crawl around on concrete. LOL
