TPS Mustang (05-12) Stainless Steel Brake Lines-FREE SHIPPING!
tpsmak
Found solution and here it is... we'll be sending out the parts within 2 days for everyone who has received the lines and ALL new kits will be receiving the updated parts.
striker 5
just order a set for my 05 with brembo brake kit next light weight rotors .
DRock
ordered a set for my car today.
Thanks for the deal guys!
chutoyy
Seattle-ish, WA
I got my set in a while ago... Haven't had time to install them yet... but here's what they look like:
Jefro
OKC, OK
Mike, is this a temporary solution or permanent one? I will send these brackets back you in exchange for the correct ones.
tpsmak
That would require us to cut the molding, correct?
Yes... just slightly.
Thanks! We carry the Brembo brake kits also AND have the lowest prices for them AND we give you more for your money such as your choice of rotors (slotted, cross drilled, dimpled) and Hawk HPS brake pads!
We also carry Baer and Full Tilt Boogie 2 piece rotors :)
Thanks! After today the sale ends on these lines :)
This is a permanent solution as you will NOT need to send anything back. Everything you have you will need to use.
Ordered a set today. thanks
Thanks!
I got mine, just waiting on the right brackets to install them.
All additional brackets have been sent.. customers should start seeing them early next week
tomkay
In case anyone is interested I used the stock brackets by removing the oem line and bending the outside flat where it used to point down. I then opened up the slot to the brake lines diameter and used the supplied spring clips to lock the line in place just like the rear lines are.
JTE_502
I just now saw this post and I will def take a set if the $99 is still good...
tpsmak
I'll keep the price the same till 12AM tonight.... after that the sale is over. So if you want a set please order it soon
tomkay
Just a heads up for anyone that did not install these yet. Do not use Ford torque specs on these banjo bolts, they will break. Ford oem banjo bolts call for 29 lbs/ft while these should be around 168 lbs/in (approx. 14-15 lbs/ft). I broke one of mine but Mike was nice enough to offer to ship out a replacement on Monday. If you go to AM website you will see someone posting the same problem with a big brake kit install. Kit looks good and everything else worked out great, just can't drive it yet which sucks.
