stang910
I'm in the process of building a Boss shortblock and I've run into a few snags along the way that has kept me from finishing my build. I hope this helps someone that may be planning a build in the future. I really wish I knew of these differences from the beginning as it would have saved me lots of time.
The first issue I came across was the plug and dowel kit that came with the new block. The expansion plug that goes in the front of the block next to the water pump came the wrong size. Ford sent me a 0.526" plug and I needed something closer to 0.563" so I ordered Dorman part# 555-092 to fix this issue.
Next was the main bolts. Ford sends the block out with all bolts. The oil pickup tube needs a studded bolt to mount to so plan on ordering one of these with your new block. I've got part# BR3Z-6345-A on order and I'm hoping it's the right one.
My latest issue is the head bolts. I went to bolt down my heads today with the Boss head changing kit and the bolts are completely wrong. I guess for '13 Ford redesigned the head bolts to a smaller and shorter design. Gonna have to make another phone call in the morning to get this one figured out.
If I run into any other problems along the way I'll update this thread.
