scuffs how to clean
Makdaddy
I am Dysfunctional
South of Chicago
So I bought a used JLT. It had a Scuff mark by the power steering reservoir
Any ideas other then painting it. The tube is the black finish from JLT
Makdaddy
I am Dysfunctional
South of Chicago
This may not show it real good
Shot at 2012-06-08
Makdaddy
I am Dysfunctional
South of Chicago
I like chemical guys blue guard II for engine bay plastics
OR Ultima Tire and Trim Guard.
Both are good products.
I thought about the tire or even the bumper stuff
Ill see what happens this Friday when I get ready for the show Saturday
Thanks
Seer
Thanks
Typically anything you use on tires, will work on the plastics and vinyls in the engine bay.
I just recommend those products because I know they hold up to heat better and do not streak.
Rasmus
You may be able to cover up the scuffs a little by using a magic eraser sponge. Bear in mind that it's about a 3500 grit equivalent.
Makdaddy
I am Dysfunctional
South of Chicago
I think Im on the right track
Used a little Eagle tire shine
its better
But I gotta do more Im taking 2nd and third at the shows I need to be High and Tight'
Before
Shot at 2012-06-27
After
Shot at 2012-06-27
Shot at 2012-06-27
And yes I got some on the Rad cover I need to finish and the covers for the struts need corrected I need to grind the top off the stem for the covers to fit after we lowered it
Seer
Meguiars trim restorer, comes in a black bottle and can usually be bought at pep boys or advance auto, walmart etc.
Don't laugh when you see what it looks like, but it usually can darken trim and plastics and cover up mild abrasions.
Drawback is, it doesn't last very long.
Makdaddy
I am Dysfunctional
South of Chicago
Ill look for that as well
Thanks
