5PointOHNO
- Joined
- Mar 4, 2011
- Posts
- 215
- Reaction score
- 0
^I'm with Mystic.
No BAP here and no window'd block (Lund Tuned).
I have 47lbs, no bap, as per jon lund with my set up. I beat the breaks off my car so it can be done safely with no bap...just saying. Im not sure why it is so far fetched to believe it was a tune issue. There are prob 6-7 people on here that are good tuners. For every 6-7 there r 25 that are ok to suck balls. I have been thru this for 15 years owning/modding n have had combos that blow up from shitty tunes......built the same combo and had it tuned by a PRO who really specializes in these cars and it was fine. I don't know either party in this case but I think the op did a good job of just stating his case in the first post and then moving on to show destruction n build pics. All I know is like one of the only coyote blocks that I've seen that had a window in it, so something went drastically wrong and I don't think it was just not enough fuel.
This thread looks like its going to get closed soon.
That doesn't happen here. We duke it out like real men.
that is insane to put a blower on a stock n/a fuel system and expect it to live past 7000rpm. are you nuts? i thought you were an engineer? i sure hope you dont do your job like you try to build cars, thats a recipe for disaster!
what company do you work for so I can avoid their products!![]()
Boost is 9-10 n it made 59x at the wheels. I will post a graph for you as well. I was also specifically told for my use that a bap was NOT needed at all. Also u obviously have higher fuel demands being at 14lbs and using e85. Believe me...there are plenty of guys running 2.3s at that boost with no bap.How much boost and at what power level are you? Let's see a dyno graph.
I hope you are joking. There are plenty of folks making the horsepower he was with the stock Coyote Mechanical Returnless fuel system. You obviously do not like the guy especially after you got a petty as talking about his profession and his wife. I believe this shows more of your true colors than the original poster and just reading this I am more inclined to believe what he has to say over you.
something you may want to consider....how much hp does it take to turn his Kenne Bell vs your Vortech?I have spent a lot of time discussing the failure with the OP and comparing why mine has lived and his did not. Obviously he is convinced the tune caused this and I can certainly see his point of view.
One thing I think may play a major roll is the fuel system. I run a BAP and ID 72 injectors. I also run the same fuel (Shell 93) with Torco race gas additive. I have dont hundreds of logs on the street and monitor AF and timing, and knock.
Another thing is I have an insanely conservative street tune. My street tune is locked at 13º timing and I leave it there. I never run the track tune on the street and when at the track the car goes through a complete cooldown before racing.
The true way to avoid another failure moving forward is the compare differences between a combo that lived and one that didnt. IMO 19º timing on pump gas, on a warm day, with smaller injectors and no BAP is right on the verge of disaster. One lean spike for whatever reason likely caused the problem.
On the same token, this single failure alone prompted me to speed up my plans for a stonger shortblock. I am now installing a Boss shortblock too. I know people get these stock short blocks to live for a while at 600 rwhp, some of us are lucky, some are not. They are all ticking time bombs when you start almost doubling the rwhp.
Fuck the comments about his decision not to run a BAP. Even if he was running out of fuel, any HALF ASSED tuner would/should realize that and stop pushing the damn car! That's why you PAY a tuner, to take care of things that you cannot. So, if he needed a BAP or any other fuel upgrades, that's the first thing this guy should have told him.
Also, let's not let this one get turned into a blame game. He came on here, respectably told his story and is giving some great info/pics on a re-build.
Someone asked if an Aeroforce monitors knock, it does not on these cars.
++++100000000000000
I for one have watched plenty of people ignore tuner advice and go right on their merry way. pop
^I'm with Mystic.
Good post. I think the OP did a good job explaining everything he experienced. All things considered, I think it's pretty clear there was a tune issue here, unless you're calling the OP a liar when he outlined his experiences (what he saw, heard, and felt while the tuner tried to dial things in).
I'm not sure why the OP bashing started, to be honest. Unless there are some biases for the tuner that we don't know about.
Man, this is WAAAAAAAAAAAAAAAAAAAY over the line IMO. Not cool AT ALL.
This thread looks like its going to get closed soon. This is the one thing that bugs me about this forum people will say this or that but never throw out good evidence supporting their case. Tuners blow up cars, customers blow up cars. Why are some people so offended by this?
This German Sheperd dude has been doging the OP since he started posting here ...he's also stated things on here that arent fact but his perception of things I somehow doubt hes ever had a FI car in his life and is just talking out his ass
Yeah way over the line, very uncalled for.
I sure hope you know this guy and that was a joke...... If not, then you must know someone involved in this......... Either way that was way over the top..........
I think he was joking with the icon..
that said if you pay 400-500 for a damn tune it better be tits when it leaves.. I have seen tuners half ass things and spend maybe an hour or some that dont even drive it and goes into fail safe!..
I was dumb to try local tuners.. stick with the main ones.. many NOW will remote tune which is cool.
That was WAY fucking out of line, GERMANSHEPERD, you are a fucking idiot!
i would think a 600 rwhp vortech would be making less crank hp than a 600 rwhp KB due to it taking less hp to actually turn the blower (assuming both blowers were making the same amount of boost)
just something to think about when discussing fuel requirements. That being said, when it comes to a boosted combination one should never skimp out on fuel system. I thought that was law. that was what my tuner told me waaay back in 02 and i never had any issues.
It was not on a warm day, and if it needed the injectors and BAP that should have shown on the AF logs.
What exactly causes a lean spike? Because I have never heard of that and if thats something that this car is going to do how can I prevent it or make the car safe for when it happens? Sounds to me like a "lean spike" is something a BAD TUNE would cause....
I thought it was a warm day...upper 70's or so. Maybe I am wrong.
You need to log the car to watch for lean areas across the rpm range. I log almost every pass at the track watching for something that can cause problems. If I see something I dont like I email the log to Jeff.
There is no way your car was detonating on the dyno, he would have never let it leave like that. But real world scenarios need to be logged and tweaked.
FWIW, I am friends with German Shepard and have talked with him about your car many times. When yours let go I was concerned about mine. I never once made fun of you or your situation but have discussed in detail your problems. I did not consider it proprietary information since you openly post it on this forum. My conversations with him revolved soley around trying to understand why your car broke and avoid breaking mine.
You may not like hearing it, but you did have some influence on this problem. You know if something is not right, don't beat on it. I am willing to bet no one runs a SC on a stock motor with 19º timing, 10 lbs of boost, and on pump gas.
There are Lund guys that have had motors break too. Shit happens and you have to move on. I know you are building a better combo now and should be ok. But at some point you have to take a look at some of the other factors that definitely played a roll in this failure rather than denying them and soley placing the blame on the tuner. This is just how I see it, hopefully moving forward you don't have any other issues like this.
I know KB runs that much timing. But from everything I read (and I am certainly no expert) that is a lot for our stock motors on pump gas.
I will not speculate any more about your engine failure, I was just tossing my thoughts out there.
I am looking forward to actaully seeing your new combo at the track and maybe getting some side by side vids. That will be allot more fun.
