6605stang
CSM No. 07SGT5687
Just like it says... going the way of adjustable caster/camber plates and would like some input on what your experience is with them.
Thanks in advance, JR
I second the J&M plates...got those on my car and love them!!!
Although they are not at the same level of adjustability of the MM ones.
All depends what you're looking for...street/strip (J&M) or all out race (MM/Steeda).
I have ground control street plates on mine and they are sweet
I have the MM ones I had like 2.6 degrees of adjustment on them. Super easy to install no bearing in them so no need to worry about that it does use the old rubber mount from the stock mounts and a metal plate.
Sent from my SCH-I535 using Tapatalk 2
You ever had trouble adjusting them? And how much camber can you actually get out of them? I have a buddy that has the J&M's and says he can only get -2 out of them and they are always sticking on him. Do you have the Street or Race version?
I'm running the MM ones and I love them. I can't remember how much adjustability they have exactly but it's a lot.
According to MM, they only offer 1.6 degrees of camber and 0.7 degrees of caster. So the only benefit to MM version is the caster adjustment.
http://www.maximummotorsports.com/s...oduct_info&cPath=309_339_346&products_id=1151
Ya, and J&M says 1.8... so I must be missing something because I've heard people say they've gotten 2.5-3.0 out of both. Not sure where they disconnect is. I want to be able to get at least 2.0 MINIMUM out of the set I get though.
It is an additional 1.6 of adjustment.
Additional from what? Stock...? I doubt it. Its 1.6 degrees of total adjustment.
- 1.6-degree continuous range of camber adjustment, adjustable without affecting caster.
- 0.7-degree continuous range of caster adjustment.
2.6 would work for me. But one thing, I was just reading their website and it says this...
"Improves dynamic alignment stability by eliminating stock rubber-bushed upper strut mount."
But your saying the rubber mount stays? Are we talking about the same ones?
http://www.maximummotorsports.com/s...=product_info&cPath=514_2_77&products_id=1151
