Whipple 10 Rib Belt Drive
b00stedgt
New York
I am selling my Whipple 10 Rib Belt Drive System. It comes with everything needed for install including directions and belt. The lower pulley is set for 10-13 psi. The snout has a small scratch on it that can be placed down so it is not noticable. I can send detailed pictures to anyone who is interested. Looking to get $849 plus shipping.
AbdullaGT500
Little Rock, AR
how hard/easy is it to install this thing with the blower on the car?
Blower has to come off, since you have to replace the snout. Overall the install is super easy. Takes 2 hours or so, if you are taking your time. I can walk you through the install if you buy it, and you should buy it! lol
HellsBells
620/677
SoCal
Ah man. I'm too lazy to take the blower off :crazy: I'd also need a retune etc...
We'll see if the price comes down :beerdrink:
Glad to see you got your new ride Abdulla!!!!!! That rear wheel is to die for.
AbdullaGT500
Little Rock, AR
Once you remove the blower enough times it becomes easy! Just do it! I went from 9 lbs of boost to 17 and didn't need a retune. Once you shred a few belts you will NEED a 10 rib! :thumb:
sportinawoody
Piedmont area , N.C.
i have an edelbrock crossover with my whipple that i can remove once i take off the blower pulley, then i could remove my snout. can you not remove the whipple crossover after removing the pulley ? removing the front 2 intake bolts and mine slides out.
