Steeda Upper Control Arms & Chassis Mount
SteedaBrandon
Banned
http://youtu.be/HdsITMgsJZ0
http://www.steeda.com/store/steeda-mustang-adjustable-upper-control-arm.html
Need to reduce wheel hop and improve traction? Steeda's upper 3rd links will do the job. The Steeda adjustable upper 3rd link for S197 Mustangs gives you the ability to set your pinion angle and eliminate the torque deflection associated with the factory piece. This upper 3rd link uses our track proven three piece bushing package using soft outer bushings a hard center bushing on the axle end. This proven combination helps control axle wind up, wheel hop under acceleration, and allows for proper articulation without deflection for improved handling and cornering stability.
Product Benefits
• Adjustable pinion angle for optimum traction
• Better handling with more stable cornering
• Three piece urethane bushings for better traction
• Competition tested & proven
Shoot me a PM if I can be of help with these.
Hani
Qatar
I've recently purchased the adjustable upper control arm (555-4105).
Can I also use the improved chassis upper mount with the arm? Can you advise the part number for this mount?
SteedaBrandon
Banned
For an '05-10, you'll need 555-4108 if you want the street setup with poly-urethane bushings. Otherwise, 555-4107 will include a rod-end instead.
Let me know if I can help you with that.
