size tires? looks sick! thinking about running the 18x10 +20 all around
I would like to know the tire size as well. My wheels are 18x10 +24 / 18x9 +24.
Thanks, yeah the car has gone up and down in height a few times the past few months mainly due comfort.I like ur car too bro, why last pics of it lowered?
Sometimes think this is an asianskater91 thread. Nice car. Need to do something about the warping in the opening of the cdc agressive spoiler......but at least you have a front plate now. ;-)
So im assuming your on coils right now? How low do you think you went to achieve the flushness in the back, 3''?
and at that height you had to rub those quarters a little, or no?
^^^WOT, why get bags for the rear? the rear can only go down to where you have it pretty much, i would get them for the front so you can just air it out and drive but thats jut me
but do you rub ur quarters at all? i cut my bump stops way to much so yeah i freaked my quarters up, paint is chipping near the quarters face to wher ei would have to paint it! fuuuuuu
lmao, well this is pretty much the only thread i can post in lol
and photography is my hobby too so sharing pics of progress is good, at least its the topic of the thread haha
but yeah i honeslty dont know how to fix it, i work in a body shop but still lmao its like the opening is too big, maybe heat will fix it but im not really concerned to much...and yeah i dont mind the front plate haha
I'm actually not, I cut them so short, too short actuallyy axle hits the frame on bumps:/ but I just need to by new bump stops and don't cut as much, I've always been on the bump stops and it doesn't ride bad at all, but yeah
Man that looks good! This makes me want the super sports now instead of eibach pros! How's the drivability? And do you absolutely have to have the camber plates??
Sorry for the late reply on this one but I currently am running stock shocks and struts and it can be rough at times but they are tired out will upgrade sometime after the turbo. And I don't have camber bolts or anything and the fronts were -1.4 and -1.6...... -1.5 is the most in "spec"
Just a cellphone pic at work!
Yes, I'm on coils. I've never really measured what the drop was from stock height to what it is now, if I had to guess it's probably a bit over 3 inches, Now keep in mind my tires are 26.6" so they are a bit shorter than what came from the factory which I believe if I'm not mistaken 27.2" in height.
The tires rub briefly on really hard launches or big bumps but that's about it.
I was thinking of the bags out back for better ride quality and stability, yeah the car wont go any lower even with bags, plus I don't think you can use camber plates with bags up front which is pretty important for me. I need to research a bit more.
What is your tire and wheel size?
I have a question on what offset to get. I can get 18x9.5 et35 or 18x9.5 et25. Im running a 275/40r18 nt555 and have to buy 2 other tires may go 255 for the front. Im slammed on coilovers and i want the tire flush to the fender. Should I go et25 all around or et25 rear et35 front?
Stay tuned we will have a new Mustang bag kit out shortly. Camber plates will be incorporated into the struts and a ton of other awesome stuff I can't talk about at the moment, but it will be killer!
Also if you did decide to go with just a rear bag kit you would go about 1/2" lower than what it looks like you are now.
