TSB Lists for 05-07 Mustang GT 4.6L.
tmcolegr
It's All About the Build
Central, FL
Looking for info on TSB 07-17-6. Anybody got anything?
Tsb 07-17-06 Buzz/rattle
FORD:
2005-2008 Mustang
ISSUE:
Some 2005-2008 Mustang vehicles built before 8/2/2007 may experience a buzz/rattle from the door panels when using the radio/CD player at elevated volumes or bass levels or voice broadcasts. This may be due to the window switch bezel vibrating against the door trim panel. This can often be incorrectly diagnosed as an audio speaker buzz or a bad speaker.
ACTION:
Follow the Service Procedure steps to correct the condition by applying foam tape to the window switch bezel.
SERVICE PROCEDURE
  1. Remove window switch bezel from door panel and separate the two piece bezel.
  2. Install three (3) pieces of PVC soft foam tape 3/8" wide by 1 3/4" long (10 mm by 45 mm) part number 164-R4901 from the Rotunda Squeak and Rattle Repair Kit part number 164-R4900.
  3. Reinstall window switch bezel and verify proper operation of the window switches.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
sevenleaf
Shesh if I was buying a new mustang and read all these TSB's I might have freaked out!
ixtlan
Hooper, Utah
Hear there is a new TSB for Axle moan.
TSB 08-21-6
Anyone got a copy?
I am hearing this second hand, but they stick some kind of dampners on the axle.
maxpayne
BIG UNIT
NJ
y
Any pictures on that "KIT"and where exactly you put that tape?on the bottom of it or on the side of it?
maxpayne
BIG UNIT
NJ
Do you guys know this one?>
M/T - Buzzing/Oil Canning Noises
TSB 08-2-10
02/04/08
4.6L MANUAL TRANSMISSION - SEPARATOR PLATE
BUZZ - BUILT BEFORE 12113/2007
FORD:
2005-2008 Mustang
ISSUE
Some 2005-2008 Mustang vehicles built before 12/13/2007 and equipped with a 4.6L engine and manual transmission, may exhibit an oil-canning or exhaust rattle/buzz around 2000 - 2500 RPM during the first few minutes of driving after a cold start. The sound goes away after the car warms up.
ACTION
The concern may be caused by the separator plate, between the rear face of the block and the transmission housing, vibrating and/or contacting the flywheel. Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1.
Remove transmission per Workshop Manual (WSM), Section 308-03B.
2.
Pry separator plate from rear face of block alignment dowels, slide out from between block and flywheel, and replace with new service part.
3.
Install transmission per WSM, Section 308-03B.
maxpayne
BIG UNIT
NJ
anyone?
tmcolegr
Central, FL
TSB 08-26-7 Water Leak Front Floor Area
Just released - a brand new TSB for this issue. Unfortunately it is a 15 MB file (has colored pictures) - too large to post. PM me if you would like a copy.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
OK, Todd e-mailed it to me, and I was able to seriously decrease the file size. It is attached now:
  • TSB08-26-07.pdf
fordrocks
Miami,FL
Is there a TSB for the fuel pump or the like on 2007's? heard it from a Ford mech. a new is on order for me but just wanted to ask.
tmcolegr
Central, FL
I think you're referring to TSB 06-9-9. Only applies to 05-06
  • tsb06-09-09.pdf
tmcolegr
Central, FL
Brand new just released today
07-08 Transmission & FEAD TSBs
  • tsb09-09-07.pdf
  • tsb09-09-06.pdf
