Seer's 2012 GT500
JEWC_Motorsports
S197 Junkie
You are gonna have to keep the engine from torquing over. Stiffer motor mounts and limiters.... Better shifter or stiffer bushings in the shifter.
JEWC_Motorsports
S197 Junkie
IMO youd probably be better off with a new shifter. Im looking and all of the bushings for the stock and ford racing shifters are just the same type of bushings(maybe alittle stiffer.) Looking at the MGW it has a better rear mount.
gtcs07
Im just kinda here
New Jersey
I have the shelby/Scott Drake shifter and absolutely love it. Also have 1/2 inch drop prothane bullit motor mounts.
GrnBullitt08
Dale Jr
Northwest Indiana
I would go with Polyurethane motor mounts and look into a MGW shifter setup. The MGW allows for adjustment, after a little testing you should be able to aid that 2nd gear lockout.
Seer
Well dealer is going to look at the transmission since they verified the issue when the car was stock.
Seer
Seer
:thumb: Let me know how it works out for you!
I should know around monday when I get the damn thing back (car). Everything I read tells me, it uses the same tune as a CJ65 and relies on adaptive learn.
tigerhonaker
TN
Thanks, hoping this TB will net me a few ponies!
Seer .....
Good-Luck with it. :thumb2:
I doubt it is going to hurt performance any and hopefully help.
Hey I took a ride, (Short Ride) in a 2013 GT-500 not long ago.
Bad-Ass !!!
Terry
Seer
Seer .....
Bad-Ass !!!
Terry
They are nice, I owned one for about 3 days before I flipped it for a quick profit :D
Ya, currently at 746rwhp, I think the tb should add about 15-20 at most. But the tip in throttle response should be improved.
Seer
So now its time to start the rebuild.
Motor popped trying to grab 4th and blew a ton of black smoke and oil all over the undercarriage.
So I purchased this so far:
Fits 2007-2010 SVT Mustang
Fits 1999-2004 Lightning with minor modification (freeze plug behind water pump must be removed)
Brand New Ford Shelby GT500 5.4L Cast Iron Block
Ford Forged Steel 8-bolt Crankshaft M-6303-M54
Manley 4340 Forged Steel H-beam Connecting Rods with ARP Rod Bolts
Mahle Forged Aluminum 16cc dish pistons
Brand New Oil Pump Installed
Other misc. parts
Approximately 8.1:1 compression ratio when used with SVT Mustang 4V 5.4L 52.7cc heads
Approximately 8.9:1 compression ratio when used with Lightning 2V 43.9cc heads
Built with these upgraded all NEW PARTS
Will accept 2V and 4V cylinder heads
Will not work with 3 valve cylinder heads
Block configured for use with 2007-2010 SVT Mustang water pump
http://www.fordracingpartsdirect.com/5_4L_FORGED_IRON_SHORT_BLOCK_p/m-6009-c54sc4.htm
As well as this:
McLeod RXT Clutch
I also got rid of my whipple 2.9, so time to replace it.
I am still exploring return style fuel systems, and am looking for a tuner to be able to do the conversion, so far no luck on the tuner part for the 11+ cars.
