So now its time to start the rebuild.
Motor popped trying to grab 4th and blew a ton of black smoke and oil all over the undercarriage.
So I purchased this so far:
Fits 2007-2010 SVT Mustang
Fits 1999-2004 Lightning with minor modification (freeze plug behind water pump must be removed)
Brand New Ford Shelby GT500 5.4L Cast Iron Block
Ford Forged Steel 8-bolt Crankshaft M-6303-M54
Manley 4340 Forged Steel H-beam Connecting Rods with ARP Rod Bolts
Mahle Forged Aluminum 16cc dish pistons
Brand New Oil Pump Installed
Other misc. parts
Approximately 8.1:1 compression ratio when used with SVT Mustang 4V 5.4L 52.7cc heads
Approximately 8.9:1 compression ratio when used with Lightning 2V 43.9cc heads
Built with these upgraded all NEW PARTS
Will accept 2V and 4V cylinder heads
Will not work with 3 valve cylinder heads
Block configured for use with 2007-2010 SVT Mustang water pump
http://www.fordracingpartsdirect.com/5_4L_FORGED_IRON_SHORT_BLOCK_p/m-6009-c54sc4.htm
As well as this:
McLeod RXT Clutch
I also got rid of my whipple 2.9, so time to replace it.
I am still exploring return style fuel systems, and am looking for a tuner to be able to do the conversion, so far no luck on the tuner part for the 11+ cars.
