700RWHP Pump Gas Full Suspension 2011 GT, North Jersey
Al Guapo
Price drop from $29k to $25k. Full bolt on turn key 700RWHP on pump gas. 655RWHP/580RWTQ on mustang dyno. Over $26k in mods. Price is KBB+50% off parts. So asking price is $16k (car) + $9k in parts. Negotiable. Cash talks. Save $ on labor, fluids, gaskets, taxes etc. Have most receipts. Mods done at $30k miles. Selling because I barely drive it. History report upon request.
Mod list:
Supercharger and supporting mods:
-2.8 kenne bell mammoth, liquid cooled, 12 psi pulley #TS10015028LCB ------------- $7,400
-KB mammoth 168 throttle body #D2700 -------------------------------------------------- $800
-ID1000 injectors ---------------------------------------------------------------------------- $900
-Comp Cams stage 3 NSR naturally aspirated #191160 ------------------------------- $1,570
-Comp Cams phaser limiters #5493 --------------------------------------------------------- $86
-Comp Cams phaser bolt kit #156-1006 --------------------------------------------------- $75
-Cam lifters x4 #9L8Z-6C683-A -------------------------------------------------------------- $26
-Cam bolts #256-1003 ------------------------------------------------------------------------ $75
-Triangle speed shop oil pump gears #TSS-50-OPG ---------------------------------------$385
-Triangle speed shop crank sprocket #TSS-CRANK SPROCKET --------------------------- $250
-JLT oil separator #3001-B ----------------------------------------------------------------- $139
-Relsche50 170 thermostat ------------------------------------------------------------------ $70
-NGK 6510 spark plugs #NGK6510 ---------------------------------------------------------- $96
-Stainless Works LTH/OR x-pipe #M11HDRORX ----------------------------------------- $1,635
-Magnaflow street series catback exhaust #15589 --------------------------------------- $775
-VMP dual fan triple pass heat exchanger #VMP-SUC021---------------------------------- $800
-VMP boost a pump #VMP-ENFOOO -------------------------------------------------------- $300
-Fan assembly #DR3Z 8C607 B ------------------------------------------------------------- $200
-S.O.S. Dual pillar pod ----------------------------------------------------------------------- $140
-Autometer Z-Series boost/vacuum gauge, 2 1/16” #2601 -------------------------------- $73
-Autometer Z-Series fuel pressure gauge, 2 1/16” #2663 -------------------------------- $230
-Raptor shift light, single mode #N/A ----------------------------------------------------- $105 -Earl's OE fuel line EFI quick connect fitting 3/8" Female to 3/8" Male #961966ERL --IMG_0146.jpg IMG_0140.jpg IMG_0148.jpg IMG_0154.jpg image0.png IMG_0150.jpg IMG_1933.jpg IMG_2182 (1).PNG IMG_2183 (1).PNG IMG_2187.PNG - $46
Total -------------------------------------------------------------------------------------- $16,178
Suspension and Chassis:
-Koni Sport adjustable shock & strut kit #101611 --------------------------------------- $790 -BMR Sway bar kit, front, hollow 38mm, 5-hole Adjustable #SB041 -------------------- $260
-BMR Sway bar kit with bushings, rear, adjustable, hollow 25mm #SB042 ---------------$490
-BMR Shelby GT500 end link kit for sway bars, front #ELK010 --------------------------- $160
-BMR Camber bolts, front 2 degree offset #FC001 ------------------------------------------ $30
-BMR Panhard bar, DOM, double adjustable, rod end #PHR012 -------------------------- $160
-BMR Panhard rod support #PHR007 --------------------------------------------------------- $70
-BMR Lower control arms, DOM, double adjustable, rod ends #TCA020 ----------------- $240
-BMR Upper control arm, adjustable, rod end #UTCA038 --------------------------------- $170
-BMR Upper control arm mount #UCM002 ------------------------------------------------- $150
-BMR Relocation brackets #CAB005 -------------------------------------------------------- $130
-BMR Shelby GT500 lowering springs, 1.5” drop, handling #SP072 ---------------------- $250
-Stoptech slotted rotors, front pair #126-61089S L/R ------------------------------------ $290
-Stoptech slotted rotors, rear pair #126-61087S L/R -------------------------------------- $190
-Hawk brake pads, front pair #HB453B.585 L/R ------------------------------------------- $175
-Hawk brake pads, rear pair #HB485B.656 L/R -------------------------------------------- $87
-SVE S350 Wheels, gloss black 19x11/10 #SVE-166912/#SVE-166902 --------------- $1,080
-Nitto NT05R tires, P305/35R19 x2 --------------------------------------------------------- $570
-Nitto NT05 tires, 275/35ZR19 x2 --------------------------------------------------------- $350
-Painted Brembo calipers (red)
Total ---------------------------------------------------------------------------------------- $5,642
Drivetrain:
-3:31 gears, ford performance #M-4209-88331 ------------------------------------------- $200
-Hays Dragon Claw clutch #96-201 ------------------------------------------------------ $1,600
-Clutch slave cylinder #BR3Z-7A508-B ----------------------------------------------------- $145
-Pilot bearing #1C3Z-7600-AB --------------------------------------------------------------- $33
-Clutch line S197 ----------------------------------------------------------------------------- $80
-Driveshaft shop 3.5 aluminum #FDSH56-A ----------------------------------------------- $840
-MGW race spec short throw shifter, 3” throw 15% reduction ---------------------------- $470
Total ---------------------------------------------------------------------------------------- $3,368
Exterior/Interior mods:
-Saleen S281 grill ---------------------------------------------------------------------------- $230
-Boss/GTCS chin spoiler #BR3Z-17626-AB ------------------------------------------------- $265
-HID fog lights #RSH11LEDHL -------------------------------------------------------------- $200
-Raxiom tail lights #49145 ------------------------------------------------------------------ $225
-MMD 5 inch shorty antenna ------------------------------------------------------------------ $21
-Ford BOSS 302 alcantara suede steering wheel # 3600AA ------------------------------- $350
-Custom fabricated cup holder, rear seat, keep drinks away from shifting area -------- $150
Total ---------------------------------------------------------------------------------------- $1,441
Grand total in parts -----------------------------------------------------------------------$26,629
Extra parts that I’ll include with the car at no extra charge. This can help you lower your purchase price:
Extras for free:
-Car cover
-microfiber towels
-Borla mufflers with factory over axle pipes.
-Lund Ngauge #LR NGauge $479
-JMS BAP
-Stainless Works off road x-pipe.
-Blowfish shift bracket for OEM shifter
How did I arrive at this price? Listed the car at KBB value, added all of the mods at 50% off. Labor, fluids, gaskets, wheel alignment, hazmat waste removal, shipping and sales tax was not included in the price. I have most receipts as proof for all the work done.
Text or email me for questions.
(201) six, three 8-19 five, six
[email protected]
