ZmanM3
The Evil One
Sucks that you popped your engine but it looks like you are off to a good start on the rebuild.
What he posted said that the 3v heads will not work.........
sent from zombie land
He must prefer an iron block over aluminum
So the blocks are interchangeable between the 2010 and 2012 gt500's? Didnt know they were that similar
That sucks Seer. Since you sold the 2.9 what are you going with?
did you open the motor in the car yet?
Taken from my other thread in the gt500 section.
So I have decided to switch to a return style fuel system on my rebuild. I have been given conflicting information from various tuners and manufacturers of these fuel systems.
Scenario 1.
Install Return Style Fuel System like how the instructions say, which is to install new hat/return style pumps into the tank and disable the FPDM's in the tune and just trigger off the fpdm's with a relay and let the regulator on the line do its work. These seems to be the easiest scenario.
Scenario 2.
I am being told that my year 2012, lacks the ability to tune out some of the trouble codes of bypassing the FPDM and having a return style pump run 100% of the time (like how they are designed) whch could cause issues like crank relearns etc.
So it was recommended that I install a return line and regulator like a return style system, as well as a new hat with larger pumps but maintain the FPDM's and just upgrade their wiring, as in run a wire from the battery straight to both FPDM's then upgrade the wiring to the hat. This second scenario requires zero tuning adjustments.
Thoughts?
I would go with scenario 2....your putting a lot of money into rebuilding this motor and car, no sense in risking any fuel related issues or possible tuning malfunction that could jeopardize the new setup. Spend the extra cash and save th headaches.
But does scenario 2 work? From my understanding is, if you run the fpdm's full time, they will burn out. But if you don't run the pumps full time, they will burn out.
