CandyRedGT
^^^ What he said!Answer is No, If you have stock 2 piece DS, I would check the center bearing.
That popping sound is more than likely your U joints binding. This is not good. When you took the LCA brackets off it changed the pinion angle and it must now be reset.Question relating to this:
I had LCAs with relocation brackets and an adjustable upper. I removed the LCA brackets and never adjusted my upper. I'm getting a popping sound coming from the rear. Around the same time I dismantled and checked my rear brakes, but everything was reinstalled correctly and torqued to spec. Will the adjustable upper not being adjusted right cause a popping sound? I have a stocker that I'm putting in soon, but this is making me a little nervous. I also know I have bad tie rods up front, but the sound is distinctly coming from the trunk.
Accelerating and decelerating is where you notice it most. Can't say about turning....maybe if the suspension is loading just right to cause a bind. Does it go "bump-bump-bump"?Would u joints pop while turning and accelerating? The popping only happens turning or a lateral slide. Been snowy here.
Sounds like time for a thorough inspection of your suspenstion linkages and panhard bar. I would do that sooner rather than later.No. Just one pop. Doesn't happen under straight line acceleration. Turning or sliding only. Doesn't happen all the time either.
It sure could.....I'd be under that baby tomorrow morning.I shook the front end down the other day. My tie rods are going, but they aren't super awful. I haven't touched the rear end aside from the upper and lowers. I think I did have to remove a panhard bolt to remove the relocation brackets though. Would a loose PHB bolt cause a popping?
Good plan...hope it aint far.Its real cold and theres a few inches of snow on the ground. I don't think I'll be doing that. I may roll up to work tomorrow and throw it on a hoist.
I've had a spring rubbing in the pocket before....made a bunch of racket.3 miles. I've been having the popping since last Saturday after I took the brakes apart though, which is really driving me nuts. I took the relo brackets off 3 weeks ago. I was also reading that the popping could be a spring or spring mount. I'm in the process of demodding my car to get rid of NVH, never figured it would make more...
Here is a picture I recently drew for someone. Hope this helps!
