if you adjusted your pinion angle, come in!
fdjizm
Drag Queen
NY/NJ
It can be confusing, but the pinion should be pointing down towards the ground lol.
torchred
My head hurts after trying to read all of this.
This.
Is their any way somebody can summarize this entire thread and put it into SUPER STUPID layman terms?
I'm installing my 1 piece driveshaft today and instructions say to make pinion angle is at zero. I have an angle finder tool (that aluminum square with a skinny ruler thingy tacked to the middle that has degrees marked).
I have adjustable lowers with CHE lowering brackets. I have NO idea what the angle is now, lol. I just know the car spins like it has 700hp but its probably got closer to 310, so maybe angle is out of adjustment?
luillo
Fort Walton Beach, Florida
This.
Here is the only step by step I have found that totally help me understand why the angles and how the angles work. YouTube also has a few videos why we need angles on the pinion for the u-joints.
Remember is not the differential literally pointing down. Is the differential angle in relation to the transmission angle. Transmission will be naturally pointing down so the differential will have to be pointing up but it's angle will be lower than the one of the transmission.
http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
fdjizm
Drag Queen
NY/NJ
You got it! That's what always confused me I thought it was literally supposed to be pointed down but it's not, just supposed to be x degrees down from the trans angle.
luillo
Yeap, and I can personally vouch for it. I just adjusted all the possible angles in my car and I can see some of the vibrations changing with different angles. So far my car seems to have a bad driveshaft. I will take it out for balance and check again.
DiMora
More Is Better
Fayetteville, GA
This.
Yes.
Preliminary foreword for Noobs: Pinion angle matters when you lower your car and / or add an aftermarket driveshaft. Improper pinion angle can make noise and wear out your driveshaft joints.
I want to help clarify pinion angle, as nobody seems to understand it, and even fewer can explain it. I don't even know if I can explain it without pictures, but I will try. (I will add pics / drawings if necessary)
A proper target according to BMR and Steeda is to have the rear pinion flange at minus 1 to minus 2 degrees...with 1.5 being a nice compromise for a street car and -2 being good for drag racing. Coast Driveline Manufacturing, on the other hand, says to set them perfectly parallel. More on that in a few paragraphs.
Here is the skinny. On our cars, according to Coast, the engine / tranny are angled such that the tranny output flange is tilted downward roughly 2.7 degrees.
Imagine if you will for a moment that we LIFT the rear of the car so that the engine crankshaft (and transmission output flange) are perfectly parallel to earth, IE zero degrees of tilt. ...THEN we adjust our upper third link so that the pinion flange also had zero degrees of tilt, it would be parallel to earth...thus our pinion angle would be zero, correct?
Some more examples of ZERO pinion angle (which is what Coast recommends...again, I'll discuss that in a moment):
If the tranny output flange was set to minus one degree, we would have to set the rear pinion flange to plus one degree...they would be perfectly parallel then...thus ZERO pinion angle.
If the tranny output flange was set to (-2) then we would have to put the rear pinion flange at (+2)...they would be parallel...again, zero pinion angle.
If the tranny output flange was at (-3) the rear pinion flange would have to be set at (+3) in order to have zero pinion angle (The Coast recommendation).
Let's discuss the Coast zero degree pinion angle recommendation and what Steeda and BMR say (Rear pinion (-1 to -2 with -1.5 being a great compromise): What happens is when we launch the car, the car "squats" in the rear...the rear pinion flange tilts up, and if you were to put a magnetic angle finder on the front tranny output flange, since the engine and front of the car are raising upward, the tranny output flange would tilt downward (in relation to earth).
If we were to run solid bushings for hard-core drag racing, we could get away with the coast drive-line recommendation of setting zero degrees pinion angle, since squat would be minimized.
However, most of us run polyurethane bushings (BMR calls them "Poly" and Steeda calls then "Urethane"...but it is all the same thing)...and those bushings flex just a little bit. Not as much as stock, but more than solid bushings.
Because of the polyurethane bushings, Steeda and BMR say we should set the rear pinion angle at (-1) to (-2) in relation to the front tranny output flange) so that when you do launch the car from a stand-still, and the suspension squats, the AMOUNT of squat is in that 1 to 2 degree range, and therefore when the driveline is under the MOST stress, the pinion angle is zero and all is parallel.
So, let's run a hypothetical scenario. WE measure a given Mustang, and the front tranny output flange is sitting at (-3) (pointed downward toward ground) you would have to point the rear pinion UP to (+3) if you wanted ZERO pinion angle (remember, zero is parallel), point the rear pinion flange up to (+2) if you wanted (-1) degree of pinion angle, and point it to (+1) if you wanted (-2) degrees of pinion angle.
If you want precisely (-1.5 degrees) of pinion angle which is a good compromise between street and drag, you would have to set the rear to (+1.5 degrees)...again that is if your front tranny output flange is at (-3) degrees.
Whew...that is my best attempt at a textual description.
luillo
Yes.
That is a very good explanation and you didn't even had pictures. Nice job man!!!!
torchred
thank you for the above posts.....unfortunately I guess I do not have adjustable lowers.....LOL shows how bad my memory is. I installed the driveshaft and attempted to measure the angle per the above instructions and it appears to be close to zero. Car drives great with no vibrations all the way up to 100+ so I'm guessing its all good for now.
BMR Tech
Traction Vendor
Tampa, FL
I'll have a quick video clip to share later today, showing what the pinion does under hard acceleration. We have Go Pro'd the shit out of suspension. It's cool seeing the reason for adjusting your pinion angle.
It's going to be a few weeks before our pinion angle video is done and available. I am thinking it is going to be highly appreciated.
Pinion angle is easy. It is even easier if you can picture the purpose of why you are doing it - without even thinking about the car itself.
If you want a -2 angle (difference) - you make the needle on the gauge move two places to the right if looking FROM the driver side.
If looking from the passenger side, you want the needle on the gauge to move 2 places to the left.
fdjizm
Drag Queen
NY/NJ
Looking forward to the vid!
This was my attempt at seeing what it does, but was in my driveway. lol
BMR Tech
Traction Vendor
Tampa, FL
For stock bushings it doesn't hange that much. It doesn't look like it could be more than 1 degree.
I can't imagine poly bushings in the whole area.
The car in the video actually has a spherical diff bearing.
As for degrees of movement, I'd guess closer to 2-3 degrees.
Hiltsy845
Thanks. The link works fine. When I click on the pic tapatalk just thinks it is an image, not a video. Could just be a phone issue.
crownaviation
http://www.tudyno.com/
Broke dafuk down
Not really sure why.
What happens when you guys click the pic?
Here is a direct link:
http://s455.photobucket.com/user/bmrfabrication/media/Kelly_Quick_Pinion.mp4.html
Even with the link mine just does this for as long as I can stand it lol..
