I drove through paint...
warpig12354
too slow
Fayetteville, NC
So apparently I drove through some grey paint. I tried claybarring it with some success but was unable to get it all off... Any help is appreciated on how to get the rest off. Yes, I'm aware my wheel wells/side skirts are dirty. Onto the pics...
flash
:helpme:
07TGGT
@user
Mansfield, TX
You will probably inducing marring though, but Seer could probably provide some better info than I.
Seer
try a heavy polishing compound, then repolish it, but that looks nasty. May need to sand.
Torched S197
Somerset, Ky
You'll be fine with thinner, your not putting it on the paint anyway. It may cause the clear coat to haze but your going to buff it after anyways right?
xocolleenox
. likes it topless .
Maryland
Is that cement paint? If so, I swear I've seen a product just for removing it from cars, lal.
EDIT: Found it.
No idea how well it works but it is made to be paint safe.
itsslow
Lacquer Thinner is a guaranteed fix, it will only hurt the paint if the paint still isn't completely cured. Polishing should also work but takes time.
Renesis07
Plainfield IL
Try some lacquer thinner
THIS. You WILL need to polish after you get the paint off. At least in my experience, it left a haze. Not sure if it was due to the thinner or me scrubbing the shit out of the car lol.
Either way, you're not SOL, it'll come off with some elbow grease.
Seer
good suggestions, lacquer thinner is the cheaper method.
The01Cav
It honestly looks more like road tar than paint. Almost like the tar patch they use to fill the cracks in the asphalt.
BlackReign
Except for what he has on his car lighter than any tar I've ever seen on a car, at least all the tar I've ever seen for road/roofing.
