IIRC, Terry hasn't found an arm yet that meets his criteria.
As for the bearing, If I am building a car for performance...I am going to do it right. I will install the bearing on the diff, every-time. As a matter of fact, an arm like our UTCA032 (massive Poly-bushing) in combination with the Spherical Diff bearing....is probably the best performing combination possible, with minimal "clunking" and banging, etc.
Binding is bad, but so is deflection in a stock UCA, or stock Diff Bushing. Keep in mind, the stock sleeve ends are designed so that the arm/bushing will not move...AT ALL. Everytime, ANY movement in, ANY direction, that movement is initiating binding and deflection. A properly designed Poly-Bushing will reduce both..
