stupid trunk question
Clipboard
looking at pre-made sub enclosures for the trunk of my 2013 gt.
i have a 1k amp and 2 10" fosgates...an answer to this simple question will either expand my options...or severely cut them...
is the trunk of the 2011+ the same as the 05-09? dimension wise
2007vistabluestang
Ohio
I'm pretty sure its different, but not 100% on that. I have 2 12" subs and I got an enclosure from zenclosures and its been great. Had it about a year and a half and is holding up great. On the zenclosure site they have boxes for 05-10 and then 11-13, so I would assume they're a little different.
Clipboard
me have them.seperate and other sites have them in the same category. Its confusing
Viperrmk
Miami
Supposedly the 2009 has 13.1 and the 2011 has 13.4 cu. ft. of cargo space.
ksack
I'd go with a custom box. I think I paid 150 for mine and have 2 10" JL Audio shallow mounts in it. It fits between the back seat and my shock tower brace so I dont have to sacrifice performance or truck space =) Amp is mounted out of sight on the underside of the rear deck. If I had a picture, I'd put them up. I can snap a few this weekend for you if you'd like.
Clipboard
yes please :)
ksack
Alright here they are. First one is a pic looking into the trunk
Amp mounted to the rear deck. Can only see it when you stick your head in the trunk
Here is a pic from inside. It is held on with 2 T brackets and some self tapping bolts from Home Depot. Works really well.
This is the original box that I had that I built with a friend. The particle board was too thin so I cracked it a couple times bottoming out on some fun runs =) The shop that did my box just recreated what I had made but with better seals and thicker board. This is here just so you get a sense of the size and shape.
