New easier method for steering wheel controls 05-10 ALL
cjust2006
Houston, TX
I finally got the cruise control to work and volume up/down and forward/reverse buttons to work consistently. I would just try redoing the connections. Use heatshrinks!!!! I re-soldered them better the second time so I think that was the main culprit. The first time I added way too much or too little on the connections so I think that was screwing it up. I also originally used a T-tap to connect to the green and black wire for SWC on the back of the radio instead of soldering.
However, the voice command and phone answer/hang up buttons still don't work at all. Dynavin Pro 8 doesn't even recognize the button input when I try to program them. Very frustrating since according to this guide all the buttons should work. However if I program the phone answer function to another button, it works. So those buttons COULD just be damaged and I might just need to get a new set of buttons.
YO! Joined up just to ask you if you ever found the solution for the phone, voice, and OK buttons not working. I'm kinda hung up on the fact that we didn't use the blue and yellow wires from the new steering wheel's audio controls. Right? And I did see on one other tutorial that the blue wire ended up being grounded AND the yellow wire also went to the WPT connector (though we don't see where he uses that), and those buttons are working for him... But they were using the PAC SWC controller... Those wires were, in fact, not used in this tutorial, right? I'm also chasing the crazy loud thump/pop when the Dynavin turns on. Am on the Dynavin 9
drh1701
Kent, WA
Folks starting to get the parts together to complete the swapout from a '06 to a '10-'14 steering wheel. I have a Kenwood head unit and I tried accessing this link knowhttp://cloud.tapatalk.com/s/61edd6c3b54a4/S197 dynavin instructions 2022.pdf but it is no longer active. Does anyone have access to the guide for aftermarket head units? Also have the guide attached from Repulsive Reject, but I want to see if there are any gotcha's that I need to be aware of with swapping the wheel out?
drh1701
Kent, WA
There is a guide that's available now. I can link you to it if you'd like. Let me know.
Also if you have trouble pm me. I'll help you
Sent from my SM-G998U using Tapatalk
Can you send me the link? I have a Kenwood head unit.
