Spring Cleaning
05stroker
Never enough power guy!
Bullard Tx.
Priced shipped (lower 48) and I will accept Paypal.
No dibs, first one to pay is the owner no matter what!
Paypal is [email protected]
1. Procharger coolant tank for 05-10 mustang GT. Its been Urethane coated matalic silver. SOLD
2. Fuel rail adapter to run after market rails with the stock fuel line. $20.00
3. Aeromotive fuel rails. You will need fuel lines and a FRPS adapter to use these. Here is the adapter. SOLD
4. MSD 30a Fuel pump boosters. (BAPS) These worked very well when I was on a returnless system. A little to much voltage to run full time on my current return system though so I removed them. $225.00 each or $400.00 for both.
5. Steeda Panhard Brace painted black. Bought it and decided I liked my BMR pc better. $75.00
6. Autometer boost gauge. I removed it to run an AEM trueboost. There is a small dig in thetrim ring. It has a new tube and fitting with it $35.00
6. Pass side air bag out of my 05 mustang. $100
8. Painless power disconect solenoid. $40
.http://www.jegs.com/i/Painless/764/...&cagpspn=pla&gclid=CJr8ssyNw7YCFQTpnAodz3gAFQ
9. ABS block with electronics from my 05 mustang with 25k miles. $75.00
10. 8 rib Inovators west crank pulley. It must me used with there balancer. There are some blemishes so please see the photos. $85.00
11. Stock 4.6 3v cams from my car with 15k on them. $50.00
05stroker
Bullard Tx.
12. Banks six gun programer part # 62986 with speed loader part# 62596 for 03-05 6.0 Powerstroke. $250.00
13. Diablo Programer with Diablo tunes for 03-05 6.0 Powerstroke . $150.00
14. Diablo Predetor Programer for Vortec supercharged cars. $100.00
15. 3" Stainless Steel cut out tubes with clamps and blockoff plates. Bought them from a member here and never used them. They are new and never used. $115.00
16. Factory P/S tank from my car with a billet cap. It could use some tlc. SOLD
17. HID fog light kit. (NOT PLUG AND PLAY) It will require you to wire up a relay to run it. I had it on my car for a short time and everything works. $25.00
18. Auto meter #3244 gauge angles for 2 5/8 gauges. $7.00
http://www.jegs.com/i/Auto+Meter/105/3244/10002/-1?CAWELAID=1710764270&catargetid=1784155608&&cagpspn=pla&gclid=CMH5iYKVw7YCFRMKnAodylsABQ
19. Factory 8.8 rear yoke from my car. $25.00
20. Two factory converter plates. One new and one used. $40.00 each
21. New factory converter for a 5r55s never installed. Been on the shelf in my garage for a couple of years $250.00
22. Factory tentioner arm. It has been coated in urathane coating and is chipped but works. $15.00
23. Two Maf sensors one used and one used for a day for testing the first one. Used is $30.00 and the one day unit is $40.00
24. Autometer Tach/shift light. Part # 4388 SOLD
25. Speed Pro/FM rod bearings std size 4.6 or 5.4. bought these for my build and the wouldnt work with my Manley Billet I beam rods. They will work fine with stock type or H beam rods. SOLD
26. Sealed Power/FM Main bearing set. I had Polydn in Houston Moly coat them before I realized I had bought the wrong bearings. These are for a 96-04 4.6 std or 02-03 F150 or Expedition with aluminum block. $50.00
27. AN fitting. $7.00
28. Autometer sending unit new never installed. $15.00
http://www.jegs.com/i/Auto+Meter/105/2252/10002/-1?CAWELAID=1710548329&catargetid=1784155608&&cagpspn=pla&gclid=CK-c_OKaw7YCFQTonAodEDcAlg
28. Chrome barb fitting. $5.00
fullmetal7777
Dallas, TX
what do the hid's look like? Sorry if this is a stupid question, ive just never looked into hid's so i dunno what this kit looks like when its on lol
05stroker
Bullard Tx.
They are fogs and bright as hell. Im sure if you google 6k hid fog lights you will get the idea. Just remember these are not plug and play.
