Help Ford will not sell me a
Eric298
Got V8?
Virginia
weird a few members on here claim that they used their aftermarket driveshaft that was for their 3650 on their new 6060 with no problems.
Stretchable driveshafts? lol
cekim
Large Member
Earth
Actually, yes - they have slip joint witha fixed flange instead of slipping on the shaft as the older transmissions did...
the CV boot they put over this joint acts like a spring pulling the flange back on to the shaft...
So, in a sense, yes, they are stretch/collapsible...
The issue is whether you either:
a. compress too far (bind) in one configuration
OR
b. stretch too far (leaving too little spline engaged)
Frankly at 3/4" difference, it might not be either, so that would explain why it works, but best to double check...
Exactly what he said. It may work, but I cannot guarantee the shaft if not used for the original application.
But there SHOULD be enough travel to do it.
