No power to my gt500 fuel pumps
Goody05
Omaha NE
I have the DOB kit and I'm running the gt500 fuel pumps. Well, I thought I had this hooked up right but I guess not. I turn the key to the on position and the fuel pumps don't kick in.
I had this wiring problem going on (http://www.s197forum.com/forum/showthread.php?t=103322&page=2) and I thought I had that solved.
For some reason I'm just not getting power to the fuel pumps. No inline fuses have popped either so I'm confused.
Good question how can I tell or check?
You could listen. You could also measure voltage in and out. If you have voltage going into the relay and none coming out when the relay is energized then it's relay related. It could be the bias voltage that energizes the relay or it could be the relay itself.
suprchrgd
Noblesville, In
check your inline fuse on the power wire that runs to the engine bay. i melted 2 pistons about 18 months ago due to the fuse holder not holding the fuse securely. mine was intermittent though.
