avinaj80
- Joined
- Feb 2, 2010
- Posts
- 1,479
- Reaction score
- 0
Hey fellas, first off is the specs of my bucket. Ancient 05 3V Manual, no drivetrain mods. Stock clutch with 135k miles. Engine has the full array of bolt ons + poly mounts.
First vibration is with the car sitting in neutral between 1,500-2,200 rpm. Vibrates good with clutch pedela pressed in, and vibrates a little more with pedal depressed.
Next vibration is pretty much in 1st, 2nd, and 3rd at that same engine speed, does not change with vehicle speed.
Now, in 4th gear, it vibrates with vehicle speed. Bad between 35-45 mph. Feels like it vibrates from the shifter back...
5th gear, no vibrations till up above 85mph, but I think that's wheel balance. There is no vibrations that I feel when I rip thru the gears. Kinda stumped on it, jacked it up and didn't feel the driveshaft loose. It is difficult at times to place into gear. Any help is appreciated. Thanks fellas!
