Clue in a new guy.
BLACK-MACHINE
living my 2nd child hood
so as much as i used the search function and as many times as i read the owners manual, i can not for the life of me fine the outside temperature gauge.. is there even one,, car is an 09-GT..
Renesis07
Plainfield IL
Unless I somehow missed it myself, I don't have it in my 06.
The car uses the maf temp and infers ambient. Ambient is reported as 2 degrees less than maf temp unless the ac is on, then it's 3 degrees less. Ambient can only be updated if the coolant temp is 170 and the car is moving at least 40 mph.
If you have a blow through supercharger setup the inferred deltas should be changed by the tuner.
Viperrmk
Miami
Don't forget that you have to change the temp gauge fluid every 5,000 miles to maintain accurate readings as well.
I wasn't making that up. At least I thought it was interesting.
TurboX
Formally Buzz Lightyear
San Anto,Tejas
My '10 has it displayed in the radio display, did the pre 10s not have this ? The sensor is also in front of the AC condenser in front lower grill.
Xorak
Memphis, TN
you don't have one. the 2010+ shows it in the radio display and the sensor is behind the grille
Black 5.0
You know, if you have a nav system, you can drive 'round and 'round in circles and make the compass spin! :snoopy
