US-1
Banned
Ok...just "terminology". The bias ply ET Streets need less air than the radial ET Streets.ET streets, 265/40/18. i'm a little confused here, these are drag radials, aren't they?
mickey thompson 3782r's
I'd start those at either 18 or 20 pounds. Hell....start at 20 psi. Work your way down in 2 psi increments. You can't get a real good result from going 1 psi at a time. You actually should be able to hook that thing at 18-20 psi.
