Fuerte
- Joined
- Sep 27, 2011
- Posts
- 694
- Reaction score
- 0
Save your cash and buy coils
What I am doing now is saving for some KW.
I have found the nice ride that you want.
I have went through 3 sets of shocks, D-Spec, Bilstein, Koni's. 4 sets of springs, Steeda Sports, H & R Sports, Ford racing, Steeda Ultra lites.
I would have stayed with the Bilsteins but I didn't have the Ultra lites when I had the Bilsteins. I would Have loved to see what find of ride that would have been.
I finaly settled on Koni adj. Steeda ultralites springs. Roush billet LCA with the stock bushings and Roush rear upper anti-wheel hope kit.
I still have the Steeda front and rear sway bars. This car rides and handles great.
This isn't a bad option.
http://shop.hypermotiveperformance....rd-Mustang-GT-V8-Suspension-kit-46-228871.htm
Do you know what the spring rates on these are?
Budget is different for everyone, let's start there.
The best bang for the buck are Koni STR.T's. If you are going to spend more that puts you into territory that is more Bilstein, Koni Sport, D-spec range. If I'm going to go there, I'd kind of want a shock I can play with and tune to my liking. Bilstein's can't do that. Great shocks on the quality side mind you, but they are what they are. And if you want a shock that "is what it is" then save your money and go with Koni STR.T. I mean, Koni damping isn't exactly known to suck.That said, between D-spec and Koni, Koni all day long for me. Better, more useful rebound damping range and no linking compression and rebound together (they do different jobs, you don't necessarily want more of both).
We all have our preferences as far as springs go. Typically I will go with Steeda springs on a street car (most commonly Sport or Ultralite situation depending).
I would avoid slamming the car with something like Sportlines, Steeda Extreme Sports, H&R Super Sports, etc. If you have K-springs those aren't bad, I'd run those and save your money (personally) and spend it on better dampers.
IIRC eibach pros are 125ish front and 170ish rear. I could be very wrong
Once again, save up your money and buy the best you can afford for the purpose you want. If you want to track your car a couple of times a year and still use it on the street look at coilovers. You might not be able to afford the best ones out there, but there are some reasonable ones that will do the trick. Such as BC racing coilovers. You could get them for around $1200. Are they the best? NO. They will work for you if your only tracking a few times a year and use your car as a DD. Good luck.
What's the advantage of this over good struts and a set of springs for a street/occasional track day car? Seems like there are so many spring and strut/shock options out there now I don't know what I would gain from coilovers. At least at my skill level![]()
Really? Hmmm.... I did not know that, I am not so sure why they chose those?
But don't coilovers give you reduced suspension travel compared with standard springs and shocks? Which is to say, aren't you more likely to hit the stops when driving on the street than you would with standard springs/shocks, even if the ride height is the same (since coilovers achieve their ride height adjustability by moving the entire assembly, while ride height variation with standard springs is achieved by varying the length and rate of the spring)?
I could see that not being an issue when comparing to the most extreme lowering springs, but what about when compared to, e.g., the Ford Racing P Springs? I would expect the latter to give you more suspension travel and, therefore, more ability to drive over rough/uneven pavement without incurring undue harshness due to hitting the stops.
Your right. Unless you are going to run regular autocross and/or track days you shouldn't waste the extra money on coil overs. You won't fully utilize the extra benefit that coils would get you and if it is still your daily, the comfort level of coils will be less than what a well match spring/strut/shock setup will get you. I suppose you could get softer springs on the coils, but then why spend the money on coils if you aren't going to wake use of the benefit of being able to run stiffer springs.
