Ill work on a how to write up here soon![]()
Looking forward to this:thumbup:
Wow what great progress and work man!!! I'd love to do that swap into my 06 GT.. I'm getting up there in mileage and I want to get a new power plant eventually.. How can you make TCS/ABS work?
The ABS works , just the TCS doesn't , not sure why but Im sure it could be corrected somehow. I don't need TCS anyways![]()
Wow! You definitely got working on it a lot quicker than Jason! Progress is amazing so far nice work, I still remember the day we picked up this roller haha
Slowly getting there!! Trying to get it done for the Car Show nov 9 in Charleston
Well done. Nice work. I'm surprised dropping a Coyote into an '05-'09 isn't more popular....
Are you not using a power steering rack?
The swap is really not that hard , if you've pulled a motor before and done some misc wiring it may actually be easy....
No dash pulling. Most of your current stuff , if you have a 05-09 gt will work. If you wire in the 2 CAN wires + and - from the FRPP PCM into your cars body harness then all the gauges will work , no dash removal. The oil pressure wire is on the C110 connector that you have to swap from the cars old c110 to the FRPP pcm connector and then the Oil Pressure guage works. I changed out the fuel pump for a GT500 one and used the existing fuel lines , just got the connectors and AN line to hook it up under the hood. the motor drops right in on the existing mounts , the tr3650 in the car bolts right up.
I used a clutch kit with flywheel from an 03-04 8 bolt modular flywheel setup , it bolts right to the coyote and has the right spline for the 3650 works like a champ. Im using the Flaming river manual rack so PS isn't a problem.
The heater fittings clip right on to the body fittings , Im using the coyote AC compressor but Ill have to get 2 fittings fabbed up because the lines have different ends on the 05-09s. Radiator hoses go right to your existing radiator , cooland bottle works perfect , FRPP aircleaner assembly sits where it should. It is an awesome swap.
