New PB at e-town today 12.58
fdjizm
Drag Queen
nice! I never saw that track up close but it looks like fun.
the go carts and jr dragsters were also running!
I think I am going to go on the 10th for the street wars, maybe make some money in bracket!
o2sys
Yes it's a fun little course, straight away you can hit 100mph+ if you are fast enough
fdjizm
Drag Queen
amazing consistency as well ....esp with a manual trans !
thanks! here is my 12.68x bracket action... I thank video games for hand eye coordination :roflmao:
Falkinman
New Jersey
I am trying to get some friends together for test & tune at Atco next Tuesday night Nov 12th. I got my 12.11 at E-town and I want so see if I can get an 11.99 at Atco. Any of you guys want to join me?
cm581978
NJ
Im going on black friday with my friend with a gt500. Im trying to get Fdjizm to go and nail his best time
Falkinman
New Jersey
Have you ever been there in Black Friday? Seems everyone has the same idea and it gets very crowded.
fdjizm
Drag Queen
I won't even go to a walmart on black friday I aint dragging my ass two hours away from home to blow my shit up lol
fdjizm
Drag Queen
C&L Racer intake
Pypes LT
Steeda UDP
CMCV Deletes
4.10's/tru trac
Koni STR-T shocks/struts
BMR LCA relo brackets
front sway bar delete
That's pretty much it for the parts that do anything.
lindertw
NoVA
I'm heading to MIR for test and tune this Friday, DA should be awesome :boobies:
made one change to my rear suspension, hoping the 60' drops some more
lindertw
NoVA
What RPM do you launch at?
I think our cars are similar... you've got some HP/tq over me, and I think you're just a bit lighter.
I run my UCA in the upper hole, and LCAs in the upper hole (BMR relocation brackets), front struts full loose, rear shocks at +4, ET street bias ply rears at 18 psi and launch around 5k side stepping the clutch. Best 60' in that config is 1.67
I moved my LCAs to the middle hole for this next test and tune. I want to pull the pass seat and rear seat junk, but I don't want that to skew my suspension testing (one change at a time).
The Feb 13 issue of 5.0 mustang has an article where JPC is running BMR bits on my08stang's 2011, and the best 60' (1.559) was with UCA in upper hole, LCA in lowest hole, front full loose, rear shocks at +2, rear tires at 15psi.
What I don't know is how much of that is a function of the 100+ rwhp that car had on me when it was tested (that and Justin B driving for the test too)
Once I see how the car reacts to the LCA position change I'll start dropping weight :thumb2:
fdjizm
Drag Queen
Hmm interesting, keep me updated on the testing.
Right now I am in the lower hole on the uca mount and the upper hole on my lca brackets. I am hooking real nice leaving at 4800rpm with just a tiny squeal from the tires.
I'm going to the track Sunday and sticking to a 5k launch to see where I am at.
I should be in the 1.68x range with 5k, if not I have to either launch higher or check out the suspension.
I am running hoosier QTP's at 16psi cold, I've read them at about 18-19 psi right after a pass.
I am around stock height though (bullitt springs).
lindertw
NoVA
I'm almost stock height with CJ springs, car sits at ~28.5" from floor to top of fenderwell at all four corners
fdjizm
Drag Queen
sounds like what works for you is going to work for me, get on that research bro! :roflmao:
Where do you shift at btw? i forgot to try 6500 I was shifting at around 6750 each time except for 3-4 kept that at 6k shifts.
lindertw
NoVA
lol
I shift at 6200-ish I think, I need to rig the gopro to watch the tach.
