golkhl
Started my TVS install today. TVS 2300 single belt phase 1 kit. Already installed the S&H fuel pump wire upgrade and Kenne Bell BAP. Today I got the intake off, radiator out, alternator modified(ground off ears), and started to modify various hoses. Did not get as much done as I was hoping but ran into some issues that ate up a couple of hours.
First bump in the road was removing the heater hoses at the firewall, what a p.i.t.a. Next up was an absolute fail trying to run air tools with my pancake compressor. Ended up going to the store and buying a Makita angle grinder, problem solved. Worst FUBAR of the day was smashing the fins on my A/C condenser. While removing the radiator I was very careful not to hit any of the fins on the back of the condensor when pulling the radiator out, problem was the A/C condenser was pressed up against the horns and destroyed the fins. I started to straighten them out, and have a fin repair tool on order, hopefully I did not do any serious damage to the condenser. Take a look at the pic and tell me what you think.
First up tomorrow is the ATI super damper install, and then jump back into the Roush install manual.
