My 2011 GT had the 401A leather option, but since I’m doing the front Recaros anyway with Shelby leather, I wanted to retain the back seat and have it match. My car is a daily driver and boulevard cruiser, so I thought keeping the back seat was a good idea.
I forgot to take a picture of the rear seat installed before I began. To remove the seat cushion, just find the two plastic “posts” under the seat that install to the floor pan. Push on them to release, then just lift up and it comes out. Takes two seconds.
Here’s the seat back after the cushion is removed.
Here’s the pivot sold the seats can fold down. It’s held in a place by one bolt that you’ll need a 13mm socket to remove it.
You’ll also need to remove the two bolts on either side of the seats. Then the whole seat back pops out.
We’ll start with the back seat cushion.
When you flip it over, you’ll see a bunch of plastic clips holding the skin on. The pics below are not all-inclusive, but you get the idea.
There is also on plastic push-pin on either side of the seat.
I used a trim removal tool to pop this. Besides the 13mm socket, it’s actually the only other tool you need to do this whole job.
A few of the clips push into slots in the plastic seat base, rather than clipping on an edge. The trim removal tool can help with these, or a pair of long-nose pliers might help too. Still, it’s not hard. Once you’ve unclipped everything, you can just pull the skin off. I removed most of them, but the clips on the leading edge were a little tight so I started peeling the skin off from the back all the way around the front, then the clips came off easily. Here’s what you’re left with .
Then grab your new skin, and start re-installing everything. This is a pretty straightforward job, with a bit of tugging to get everything seated just right. (pun intended) Make sure you get the seams driven down into the grooves in the foam so the Velcro attaches and pulls everything tight. Here’s the finished seat cushion.
Sit back and take some satisfaction at completing the cushion, because the seat backs are a little more involved. Still not difficult, but it takes a little longer. Here’s your starting place.
Flip it over, and look at the corner for a small Velcro tab. You’ll need to unhook this.
Moving to the other corner, you’ll have the familiar plastic joints that are used all over the interior upholstery. They’re basically interlocking plastic tabs that you snap together and fold over to hold everything tight. Once you take one apart, you’ll see how they work and go back together. Lift up, and pry them apart. This corner one is easy and you can actually slide the two pieces apart.
More of the same with the large clip at the seat bottom.
Once you get it open, lift the flap and you’ll find some Velcro strips attached in the middle. Detach these.
