Tim, your bracket looks good but you can buy the Ford bracket. It's the stock setup for the 2010 Mustang GT. It locates the PS reservoir in front of the idler pulleys instead of over in front of the valve cover.
Tim ...
It is all coming together nicely ^^^.
Terry
Tim ...Thanks guys. Going slow but we've got another 60 days or so of cold temps around here so no need to rush.
Im not really familiar with the aftermarket fuel set ups. Does the Y block split the feed line to the front of both rails, and then the rear of the fuel rails run to the outside of the regulator and the bottom of the regulator goes back to the tank?
