Should BMR make an axle tube brace for the S197?
  • Yes
    Votes: 253 94.8%
  • No
    Votes: 14 5.2%
  • Total voters
    267
luillo
Fort Walton Beach, Florida
If your trans is aimed down 2.5 and your pinion is aimed down 1.5 then your pinion is aimed too high. You want the pinion pointing lower than your trans, not higher. Pinion would be down 4 degrees to have a net -1.5 pinion angle.
I must be interpreting all of you guys instructions wrong. I been following these instructions in these post and started to get some results.
http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
Next weekend I will have time to get the car level I n the lift and measure it good. Now that I adjusted my UCA for more angle I will be able to set it right at -2.0 then -1.5 and see what happen. I am almost sure I will have to take the DS for balance.
BMR Tech
Traction Vendor
Tampa, FL
Correct.
Looking from the driver side.....how many ever places the gauge moves to the right, is negative XX. So, if you read -2.5 at trans/crank....and want a -1 pinion angle, then you move 1 place to the right, and end up at -1.5 at the pinion (needle moves 1 place to right)
A positive angle would be the needle moving to the left. So, if you are at -2.5 and you set the pinion at -3.5...you will have a +1 "pinion angle".
Negative is left of zero on the gauge....but if you use the gauge in the same manner/orientation - the negative and positive #'s do not "jive". For example, the more "negative" (down) you face the pinion - the more "positive" reading you will get on the gauge.
luillo
Correct.
That is exactly what I think has been confusing me. But that explains a lot.
BMR Tech
Traction Vendor
Tampa, FL
Played around a little bit this morning with our cars in the R&D facility.
It is amazing how difficult it actually is to get a proper reading with these cheap angle finders. It is definitely important to ensure that the complete true flat spot on the finder, is perfectly flat when utilizing the magnet. That damn magnet is more harm than good, from my findings.
Anyhow, IMO the pinion flange machined flat spot and the rear machined surface are about as "true" as it gets, in terms of similarity in angle.
Here is the angle of the rear of the flange, using a square. In this picture - it is the exact angle. I ensured the complete flat portion - was flat against the square. This is why you will notice the angle finder is slightly shifted on the base plate of the square.
Here is the angle of the machined flat spot that we recommend taking angle measurement from. This is somewhat trickier than it seems, and I will try to remember to tell people to use a square off the backside, if possible. By using the magnet on this piece, I was able to almost swing a full degree in each direction, based on the position. I confirmed this angle reading with the base plate of the square - but it was WAY too difficult to snap a pic of that.
Here is a snapshot of the square mounted to the two spots. There is a "speckle" of light coming through, which is a "nick" in the metal. The light is very bright.
Here is a snap shot of the angle finder placed on the square I was using. They match perfectly.
Ignore the wheelie bars, engine on stand, and the other cars on the lifts. Just a typical day of hot-rodding at BMR Suspension.
Those wheelie bars are silly! I keep telling my boss he is a wimp. He replies with "once you approach 7's Naturally Aspirated with a manual trans, come talk to me"
That's all for now.
luillo
If someone where to have vibration ONLY at certain speed, 75 mph and up and everything else has been corrected, tires, axles rotors and pinion angle is within -1.5 to -2. Could it be drive shaft balancing or related? Also drive shaft has about .10 Run out in the front and .5 in the back
wbt
You aren't going to get the bottom of the square perpendicular with the back of the flange. Let's take the D/S out of the car and square the bottom of the flange up with the front and see where we are.
If I get time this weekend from running some 10.5 cars I'll get under mine, remove the D/S, and see where it stands.
BTW - The area to check with the light is the bottom of the flange, not the back.
CPRsm
Wrong. "IF" the part was not perpendicular, the light will be on the opposite side that is laying flat. It can go either way.
wbt
You bet. Put the stock D/S back in and compare.
Look at the second to last pic in his post. It is very suspect. It is impossible to get to the centerline on the backside of the flange to get an accurate comparison using a square.
When I get time I'll compare with the D/S out on my car and post results.
Between now and then.....:2g1c:
Holy cow! The man who used a piece of scrap tubing as his 'square' is criticizing somebody for using an actual square. Too fucking rich.
:stfu:
JEWC_Motorsports
S197 Junkie
Kelly in this image the square appears to be on the bolt. Is it or no? I ask because i see light at the top of it and bottom. Just want to be clear where to get my measurements from.
CPRsm
It's suspect to you because you can't admit you're in denial.
Wrong again. It doesn't matter what angle the square lies on the flange. It doesn't matter if it pointed thru the center of the flange, or runs against two bolts. It's all the same plane. That right angle will not change.
Oh please do hurry. We all eagerly await the hobbyists seal of approval
BMR Tech
Traction Vendor
Tampa, FL
It is not on the bolt. It is between them - flat on the flange.
Measure from either place that I pictured. I got "0" on the back part of the flange....and "0" on the bottom.
wbt
:stfu:
You are as dumb as they come.....
His pic is suspect and I will double check the measurement on my own car and post results regardless if is truly square or not. 0 bias. You act as though I am trying to sell something to someone.
BTW - Not one thing in this thread pertained to your dumb ass however you feel the need to jump on anything I post because I questioned your buddy and his results. Mine differed. Your's differed. You have not one logical explanation for it....just speculation.
CPRsm
Nothing in here pertained to you either. But yet here you are, flaring up again like the little hemmroid that could. I'm not acting as if you're trying to sell anything. I didn't post because you "questioned my buddy." I posted because you lack the ability to post something different without being an asshole. You can call it 0 bias all you want. Everyone sees thru your bullshit. And others have commented in here about it already as well. Let's hope for your sake it's not square and you're right. Having a different opinion/measurement and speaking up is one thing. Eating crow after being an asshole for no reason, takes more than I think you possess. Can't wait for the backtracking again.
Gabe
Whippled Coyote
This thread was informational until you chimed in, now it's a shit show.
I don't know you from a hole in a wall, but from the way I've seen you behave/talk on this forum, I will never do business with you.
fdjizm
Drag Queen
That's one of the most helpful mofo's on the forum.
let's keep it movin! hopefully BMR will have some axle tube brace teaser pics soon :2g1c:
