Headers are uneven!
Status
Not open for further replies.
Sarge1400
Nebraska
Measure from the ground up to the pipe to see if they're really uneven.
Unless you're just yankin' our Franklin, then kindly just bugger off.
07 procharger
Addicted to modding
Red Deer Alberta
It's the headers. You need to bend it up or bend the other down till they are level.
Then you need to refill your OCD meds.
Scott_0
OxFORD, Pa
dude I'm really starting to think you are simply an attention whore smh
sent from my S4 using Tapatalk
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Sooooooooooooo I guess I'm gonna have to split the difference of the 1/4" between the two sides to bring it back to level????
Raise the drivers side 1/8th" and that should lower the passenger side an 1/8th" = LEVEL???
LS1EATINPONY
The Banker
So when you shim the motor mounts what are you going to do about the motor not being level????
foxxxtman
I think your speedometer isn't perfectly horizontal when your car hits 100, you should adjust your speedo so that it is or make it floating so no matter what speed you go the needle stays level :) hahahaha I honestly never even thought of measuring my exhaust down there, if the tips look even and such then i'm good!
Status
