HUGE garage/storage unit sale. Lots and lots.
19COBRA93
Ford Racing
Clinton, Ut
It's time to clear out all my stuff I've been storing. Everything includes shipping to the lower 48 (I don't ship to Canada, sorry), and is priced to sell. What you see is what you get. If it's not in the picture, it's not included. Parts will ship UPS within a day or two of payment. Paypal only.
If it's shown here, it's still available. I'll continually edit the list as stuff sells. I have multiple quantities of many of the parts as well. And I have many more parts (mostly interior) not shown that I'll add as I get pics of them.
I won't hold parts. I've been burned far too many times.
Radio/HVAC control bezel. Like new. Flawless. $45 shipped.
05-09 light grey center console base. New takeout (just dusty), with aux input. No lid, or top cover. $70 shipped.
A-pillar trim pieces. New takeouts. Both light grey and black, LH and RH. I have many of each. $40 shipped each piece.
http://s531.photobucket.com/user/19cobra93/media/IMG_91161_zpsb4cd1698.jpg.html
Base GT scuff plates. New takeouts. Black. $40 shipped per pair.
2008 GT manual fuse box assembly. Works perfect. $60 shipped.
New steering shaft, both pieces. $60 shipped
Steering column shrouds. Upper and lower. Hardware included. $40 shipped for the pair.
Steering column electronics. This whole assembly includes the clock spring, turn sig switch, and wiper switch. All assembled, works perfectly, hardware included. $100 shipped for the assembly.
Drivers side door trim/mirror switch. New takeout. Works perfectly, $30 shipped.
4.6L/5.4L oil pan, pickup tube, and steel windage tray. For without sensor. $100 shipped for all.
Interior trunk side trim pieces. New takeouts. $60 shipped for the pair.
Hood latch cable, $30 shipped.
Throttle pedal and sensor. Works great. $50 shipped.
05-10 3V fuel rail assembly, with sensor. $60 shipped.
Cooling fan resistor/relay, works perfectly. $30 shipped.
05-10 3V Heater core hoses, $30 shipped for the pair.
Black LH under dash trim panel, excellent shape, no holes. $40 shipped.
Passenger side kick panel, excellent shape, includes fuse access door, $40 shipped.
New takeout 05-09 base GT steering wheel. Like new, includes cruise switches. I have several, $50 shipped.
New spare tire jack. Never used, I have a few. $40 shipped each.
New factory lug wrench with cover, never used, $30 shipped each.
19COBRA93
Ford Racing
Clinton, Ut
More....
New takeout window regulator assembly. Includes motor. LH. $60 shipped.
New takeout RH window regulator, Includes motor, RH, $60 shipped.
Upstream/front 05-09 GT oxygen sensors, work flawlessly. $40 shipped for the pair.
4.6L engine back plate/main seal housing. $30 shipped.
Radiator upper brackets. $30 shipped for the pair.
05-09 RH, passenger side airbag. $100 shipped.
Turn signal switch, new takeout, $30 shipped.
Windshield wiper switch, new takeout, $30 shipped.
Interior manual flip mirror, new takeout. $30 shipped.
Black glove box assembly. $40 shipped.
Horn pair, work great, $30 shipped.
A/C accumulator, 05-09, $30 shipped.
4.6L 3V engine oil dip stick and tube, $30 shipped.
Brand new in the bag OEM Ford black floor mats, 05-09, front pair, a few sets, $40 shipped per pair.
Drivers side kick panel, black, excellent shape, $30 shipped.
Radio side bezels, black, great shape, $40 for the pair.
GT500 intercooler reservoir, $30 shipped.
05-09 airbag clock spring. Works perfect. $30 shipped.
GallopingFord
I'm Cam - Mr. Indecisive
Northern Virginia
I really wish you had that underside dash panel for sale earlier... buying a new one isn't cheap at all. Lol
What year is that steering shaft for? IIRC the 2010's are stiffer.
Also did you find a set of paired washers for a DS?
19COBRA93
Ford Racing
Clinton, Ut
I don't know what year they're from. I'll get a look at one and see if there are any numbers on it.
I can't find the paired washers. I know I have a set, but they've walked away on me.
STEVE_POE
coyote powered fr500s
Cincinnati
galloping ford I have a ton of black interior panels from road race builds most of the panels are stripped from the dash for what I'm doing. what part are you looking for ?
BadPiggy
Hooligan Ahole
Knoxville, TN
Sam,
I'm down for the "Trunk Cargo Net" for $40, shipped.
Need your PayPal info, please.
Thanks!
KonaBlue11
I'm not sure if the 05-09 base GT steering wheel will fit a 2011. I don't even need it to do anything specific with the wiring/electronics controls. I just want a way to steer my car for a day or two while I consider doing a customized mod to my current Boss suede steering wheel. So if it does fit for certain, I might be interested in taking one off your hands.
GallopingFord
Northern Virginia
It should work just fine. The 2010 base steering wheel is a 05-09 style, and the steering column didn't change in 2011+
19COBRA93
Ford Racing
Clinton, Ut
Yes it will definitely fit an '11. It won't plug in, as the connector is different. But the mounting is all the same.
Gabe
Whippled Coyote
Interested in the "Base GT scuff plates. New takeouts. Black. $40 shipped per pair." and the trunk net if not sold yet.
Will those scuff plates fit a '13 ?
I broke some tabs on both of mine ...
19COBRA93
Ford Racing
Clinton, Ut
Yes, they'll fit a '13. And as of now, the trunk net is not sold.
