To those that have switched from OEM to the GT500 strut mounts, have you noticed any difference in steering feel? I'm aware the GT500 strut mounts are sort of a band aid fix for clunking noises, but I'm hoping to hear honest answers
Great for someone that doesn't want to spend a bunch of money on aftermarket components.
I wish I were such a person.
There is NO camber adjustment on either the oem or GT-500 strut mounts for 05-14 cars, GT/V6/GT-500's. My 2010 ended up with -1.1 deg on the pass side....and -1.4 deg on the driver's side. At least let's get the same camber on both sides. Ford sez anything from -.5 to -1.5 is within spec. And they mean one side could be -.5 and the other side could be -1.5.
In desperation, I tossed the oem stut mounts and installed the steeda heavy duty strut mounts..which allow +/- 1 deg of camber. ( that's +/- 1 deg of whatever you have to begin with).
There are plenty of oher stut mounts out there that will allow for camber adjustment...and some will also include caster adjustment.
I set em both for -1 deg. I run a staggered setup from may-oct, so can't rotate the tires. I could go as high as -2.1 deg on both sides... but was concerned about tire wear. At the time, I thought I would play it safe..and set em for -1 deg. They can be increased a bit at a later date.
Stock, these cars can only have the toe adjusted. If you are going to install lowering springs and shocks, that is the time to install a strut mount with an adjustable camber. Both the oem + GT-500 strut mounts are one time use only. If they start clunking on you, and you replace em with GT-500 versions, they could clunk again down the road.........and you still have no camber adjustment.
To those that have switched from OEM to the GT500 strut mounts, have you noticed any difference in steering feel? I'm aware the GT500 strut mounts are sort of a band aid fix for clunking noises, but I'm hoping to hear honest answers![]()
Well, there is a slight amount of camber adjustment.
You can flip the Upper Mounts 180 degrees out, and it will gain about .20 degrees of camber. I recommend this quite often to my customers who panic about being beyond that -1.5 degree "spec". For example, -1.7 is common for our front lowering spring. Flipping the mounts will typically put the car back into the -1.4 to -1.5 range.
Then there are "free mods". Not really free, but, you can modify the strut to spindle mounting holes. Between flipping the USM 180 degrees, and slotting the strut holes, you can get a decent amount of camber to work with.
You can also slot the A-Arm mounts.
But yeah, in terms of easy adjustment - definitely none available from the factory when speaking of a substantial range.
If you want to make a real change in handling get an adjustable, spherical top mount camber plate and remove a hunk of rubber the size of your fist plus gain much needed camber adjustment.
Hey BMR, can you talk a little more about how you slotted the mounting holes? I'm curious.
No significant enough benefit and no need to change the mounts unless you have the struts/springs out for replacement.
However; If you are replacing the struts or springs then get the GT500 mounts as the stock mounts are not worth saving.
Usually no need for Camber Plates unless you want to switch back and forth from track use to street settings.
That's one helluva lot of work and effort.... to flip the oem strut mounts 180 deg..esp if you are paying somebody to do it. I also looked at camber bolts...but quickly dispensed with the idea...too weak imo.
Even with the GT-500 /oem strut mounts, it's a crap shoot with what camber you will end up with. My goal was to at least get both pass + driver side the SAME camber, regardless of camber. With the steeda heavy duty strut mounts, I can make both fronts exactly the same...and set em to anything I want. They are not cheap, but very well made.
I took a really long hard look at the situation..and decided to spend once, install once. If you are paying somebody to install this stuff, the labor cost is identical, so you save nothing. IF your replacement OEM / GT-500 mounts start to give you grief, what's next, install a 3rd set ? Toss in the labor for the 3rd set, and you lost it right there.
Well... in my opinion, slotting strut mounting brackets is generally a really bad idea. The only time I would suggest it is if you race in a class with really jacked up rules, where slotting struts is the ONLY means of camber adjustment allowed (SCCA F Street, which allows this for certain S197s due to a factory TSB referring to the 2007-08 Shelby Mustangs).
Why? Because adjusting camber in control arms or top mounts is a better solution. These methods are more repeatable and have better "tunability" than slotting holes in brackets. And there are also the unforeseen changes to slotting strut holes, including:
We've gone to great lengths on several strut housing "re-dos" to fill in slotted holes. Either with welded in slugs (above) or bolt in slugs (below). This makes the strut not slip or come loose under heavy side loading.
- Lowers inboard wheel clearance.
- Changes SAI geometry
- The slotted holes can SLIP under heavy loads. We've seen this happen many times
- This slotted junction can weaken the strut mounting bolts, which in the past had a tendency to break... a lot... on SCCA F Stock Mustangs.
Not just saying that because we sell camber plates, either. We've seen and understand the downsides of slotted struts...
